Number plate bulb warning light
stefoster Feb 6, 2013
  1. stefoster
    stefoster Member
    56
    Hi all,
    Recieved some led bulbs and fitted them, both number plate bulbs are working but my number plate light warning on the dash has come on!
    Any ideas why?
    Steve
  2. mmalh0151
    mmalh0151 Member
    170
    I am new to Audi but were the bulbs canbus? T8rups on here sells them for around £5/£6 and do not flag up errors
  3. stefoster
    stefoster Member
    56
    These are the ones from T8ups, I'm sure there is a reasonable explanation as to why its happening..
  4. NHN
    29,417
    1,740
    Year of car helps to get you some advice/help, research the site also as this has been discussed a fair bit.
  5. stefoster
    stefoster Member
    56
    2009 59 plate black edition sportback
    I've tried searching but no joy!
  6. mmalh0151
    mmalh0151 Member
    170
    I read on my travels that they may need coding at 2009 if its a facelift? I could be wrong.
    On a separate note... I have fitted the trups supplied bulbs and they are superb!! DRL's are brilliant as well!!
  7. NHN
    29,417
    1,740
    Certain years, newer ones have the possibility to code the led number plate lights yes, but needs a specific version of CE board & firmware installed in order for that coding to be accepted.
  8. Zak0123
    Zak0123 Active Member
    540
    76
    There's a topic about the cold weather making the bulb out light come on, happened to me so I put the OEMs back in, the others haven't really worked properly from day one for me. (2011 plate)
  9. grr666
    grr666 Member
    171
    19
    I got a bulb out warning on mine last weekend when I went out for dinner
    with the wife. They were fine driving out there but after our meal the temperature
    had gone down from about 4 degrees C to -2.5 degrees C and as soon as I started
    the car I got the bulb warning, hopped out and checked and both were out.
    Switched off ignition, back on again and they were fine again. Just a glitch I reckon.
  10. stefoster
    stefoster Member
    56
    It's driving me insane! I'm going to put the originals back in and see if its the led bulbs I put in!
  11. rennie
    rennie Member
    32
    Why not put Audi led's in which should work up to 2010 year if I'm correct, it's been a while since I looked.
    Mine have worked perfectly (2008) - just remember to bend the springs out (or there abouts) to match originals.
    Grab a cuppa and read this:
    http://www.audi-sport.net/vb/a3-s3-...di-number-plate-leds-fit-a3-8p-plug-play.html
