Now where do I find my ABS control module?
dieselfitter251 Sep 16, 2008
  1. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    A4 avant q '97...aaaaand. If I unplug it, remove it, can I still drive the car & more importantly will it stop!? :uhm: It's goosed. I'm considering sending it away to get repair or swapped for a refurbished unit.
    Or...... anybnody got one? :sly:
  2. dieselfitter251
    1,120
    Can I just unsrew the electronic bit from the pump or will have brake fluid spraying everywhere?
  3. Broken Byzan
    13,244
    468
    Electronics are seperate from the pump, so it will not leak. It will drive like a normal car with no ABS so drive accordingly
  4. dieselfitter251
    1,120
    Cheers dude... Any word on the reputation of
    [FONT=Verdana,Tahoma,Arial,Helvetica,sans-serif][/FONT][FONT=Verdana,Tahoma,Arial,Helvetica,sans-serif][SIZE=+3]ecu[/SIZE][/FONT][FONT=Verdana,Tahoma,Arial,Helvetica,sans-serif][SIZE=+3]-testing.com?[/SIZE][/FONT]
  5. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I had faulty one on mine (got shorted and blew) picked one up from ebay for £5 :D
    it is under the back seat lower foam section (the butt part) and car will drive without it but no abs and you have permanent warning on dash.. well that's what happened to mine
  6. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    I used BBA-Reman to sort mine, and I can't recommend them enough. Cost about £120 I think and only took 3 days.
