Notchy 2nd gear? Anybody tried this? S3 8l
S3 rpm Apr 26, 2012
  1. S3 rpm
    S3 rpm Member
    57
    Hi all,came across a link I found on here and think my car may need the same thing doing,it's called vw gear linkage reset on YouTube,in the video the guy has the gearbox and gear stick out of the car,anybody done this obviously with the box in the car??
    Easy job or a pain in the ass?
    rich
  2. Sam_
    Sam_ Down under
    3,038
    480
    Resetting the linkages is pretty easy to be honest. Access isn't too bad from memory. I just fitted the dieselgeek sigma six so it was done at the same time. I still get a slightly notchy 2nd sometimes but I just go easy on it until it's warmed up. Box's are always a bit notchier when cold. It's nothing compared to my old Quaife straight cut box haha.
  3. S3 rpm
    S3 rpm Member
    57
    So quite easy then? Enough room to move around in there? Will I need to remove air box or anything else?
    Cheers man
    Rich
  4. superkarl
    superkarl MAN OF STEEL
    9,569
    2,464
    piece of cake. no need to remove anything, just a case of lifting the gearstick gaiter up.
    you can just about get to the black locking button
  5. Dani_B19
    9,343
    394
    WOrd of advice, if you have big hands then the black buttons is a biatch, i couldnt get my hand in so had to use a large flat head, just be careful not to pop it out.
  6. Az
    Az Hard slammed!
    1,023
    35
    Can someone expand a bit more on this please? My 2nd gear is a bit notch when cold, I've just had the gearbox oil changed but it's only slightly better really, I've never heard of this reset though.
    Tony gold likes this.
  7. S3 rpm
    S3 rpm Member
    57
    Thanks guys,il get it sorted tomorrow...as well as looking into a grinding noise which only appears when it's raining...strange I know
  8. superkarl
    9,569
    2,464
    [ytv]tp9ggefOjAE[/ytv]
  9. S3 rpm
    S3 rpm Member
    57
    Mate type into YouTube "vw linkage reset" it's the video with the gearboxes out of the car so you can see what he's doing. I wasn't sure if I would have enough room to get to the gearbox
    Rich
  10. S3 rpm
    S3 rpm Member
    57
    Thats the video I was looking at,didn't know how to post links or vids,cheers bud
  11. Az
    Az Hard slammed!
    1,023
    35
    Ok cool, thanks for posting the link! So this re-alignes the linkages and makes 2nd gear a lot smoother to engage when cold then?
  12. S3 rpm
    S3 rpm Member
    57
    I'm guessing it will just make certain everything is aligned properly and possibly sort the 2nd gear issue out,if you do yours before I do mine let me know if there's a difference mate
    Cheers rich
  13. S3 rpm
    S3 rpm Member
    57
    You done yours yet mate?
  14. superkarl
    9,569
    2,464
    it makes sure the gear cables are the correct length and there is no slack in them. technically it should make gear selection easier, but it wont work miracles.
    if you have notchy gears, consider replacing the dogbone mount bush with a poly one. this has improved gear selection for many members (minimises the engine rocking back and forth between gear changes).
    failing all those, id guess you're into synchro issues.
  15. S3 rpm
    S3 rpm Member
    57
    Yea I've done the dogbone mount,fitted the red powerflex one,feels aload better and more precise. As for the notchy 2nd gear il probably do the gearbox oil change before I start thinking of synchros.
    Cheers Mate
  16. chippie
    chippie Member
    91
    I think these gearboxes are common for notchy 2nd gear, mines done it from new, just have to take it steady, ive also found that if its reved quite high it seems to go in easier.
  17. S3 rpm
    S3 rpm Member
    57
    Yea so I've been reading,thought I'd try a few things to improve it,noticed your in west Yorkshire,where abouts pal?
  18. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Great video! Mine's occasionally notchy into 2nd from cold so I might try this. If my hands can't reach the black button then I'll dangle one of the kids in to press it in for me.
  19. aterro
    aterro S3 YO
    272
    Can anyone link me to the video?
    It just keeps saying private.
  20. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,292
    370
    aterro likes this.
  21. aterro
    aterro S3 YO
    272
    Thanks dude.
    Does it matter as that's a 5speed in video and mine is a 6?
