Not the normal LCD problem
billybaggins Mar 25, 2013
  1. billybaggins
    billybaggins New Member
    23
    I have done a search and seems most peoples lcd dis problems are pixel problems... Mine is completely blank, with no red back lighting.
    Its not off on the reset button, tried this.
    In addition to this i have no fuel light and no auto checks upon switching on, so seems the display is powerless or all bulbs have gone which i think is unlikely.
    I have removed and checked fuses 5, 12 and 15, all are fine and seem good and tight in their slot
    Anyone had this problem or know any fixes?
    Thanks in advance for any help... ps its a November 1998 tdi se
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Missing pixels is down to a connection issue on the board.
    The same sort thing happened to mine.
    It could have completely lost connection.
    You could attempt a DIY fix or send away for repair.
  3. billybaggins
    23
    Is it worth removing cluster then and looking for a wiring issue behind it? What sort of places repair this type of thing, not a normal autospark is it?
    cheers
  4. HibiscusS4
    HibiscusS4 Member
    97
    Its normally the screen delaminating rather than a connection issue. I put a new screen in myself and was a real PITA. If its not lighting up at all then its probably the bulb or the posative feed to a number of bulbs if you have a few out.
  5. aragorn
    18,663
    878
    If the backlight is off, its not an LCD issue... The backlight is totally seperate...
  6. billybaggins
    23
    Thats what i thought, it's 100% dead. Do you know how to sort the backlight issue?
  7. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Are you totally sure it's not just turned off?
  8. billybaggins
    23
    Yeah ive tapped the stslk button, held it and played about. Surely you aren't able to turn the fuel gauge off and it would override it being off?
