Not sure if problem or not.
vwgtiking Dec 22, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,029
    The other day after a lot town driving I noticed the normal biting point felt like the car would stall and a slightly hesitant and vibrate. Therefore required more throttle. I also notice sometimes when I come to stop and move the gear neutral it makes a slight vibration again like it make stall. But there is no drop in revs.
    Anything I should check? I have vcds so I will do a scan. The onboard computer says the car is "OK".
  2. vwgtiking
    1,029
    Any advice?
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    DMF on the way out? How many miles it done?
  4. vwgtiking
    1,029
    It's done 105k. It rides a little high and it's not slipping.
  5. Dan11
    Dan11 Active Member
    169
    Mine felt similar to this the other day, turns out one of the engine mounts was no longer doing what it should!
  6. vwgtiking
    1,029
    Engine mount will cause me to rev higher to make it move without shuddering so to speak?
