Not stricktly B5, more a VAGCOM question...
SonicDeathMonkey3
I've got VAGCOM for the S4.
Father in law in having trouble with his VW Bora auto-locking. It's done it with his keys in the car!
Was wondering if any of you knowlegable lot know how to disable this "feature" with VAGCOM?
cheers
The only time it should auto lock is over 15mph, to remove just do the opposite off this
+32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
So if its set to auto lock -32 instead of adding it keep the original coding handy just incase.
The only other time i know of that it will auto lock is if you unlock the car with the fob and then dont open any of the doors within a few minutes.
If thats the case, the only way you could lock the keys inside the car is if one of the door microswitches is faulty, allowing you to open the door and put the keys inside, without the CL pump realising the door has been opened.
