Not happy, possible petrol line crack/split!!!!!
Booth_S4 Mar 22, 2007
  1. Booth_S4
    Booth_S4 Riding on V8 power
    658
    My car has been funny on start up for the last few days. I noticed the smell of petrol when i was getting in and out of car, then on start up it wasnt firing up on the first occassion. I am having to re-turn the key for a second time and it fires up no problem.
    Now ive found some petrol on my driveway, so either the petrol line is split or its the petrol tank.
    Anyone had anything like this happen before? How much is it likely to cost to rectify?
    thanks
  2. mikeoh
    mikeoh New Member
    14
    It could just be your fuel filter. If the leak is coming from the drivers side near the rear quarter near the tank then it might just be that. Apparently they're prone to rubbing on the tank and putting a hole in themselves. I got to work one morning and found a puddle slowly forming under my car. I got it recovered to a garage who charged me £32 for parts and labour to fit a new filter :)
    I was quite relieved!
  3. Ess_Three
    Ess_Three Active Member
    5,383
    14
    My S3 had a split in it's fuel filter as well...
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Blimey that sounds like a serious fault!
  5. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    If it is the fuel filter, consider changing it yourself.
    It's around £4-6 and takes approx 5-10 minutes to fit..
  6. Caesium
    4,879
    Might want to depressurise the fuel system first or get a face full of fuel at 60psi
  7. Dave_Bayern
    1,913
    Unless the engine is on and running the fuel filter is not under pressure.
    I've changed enough, it kinda dribbles out. Mind it does hold a suprising amount of fuel considering its size.
    You need to clamp off the pipes and swap it out. really simple.
  8. Caesium
    4,879
    Must be different on the Audi then, the last fuel filter I changed was well after the engine was shut off, and the fuel line was still pressurised.
  9. claudefrog
    claudefrog Member
    372
    i agree with A4Quattro
    the s3 lines are still pressurised when changing a fuel filter.. and TT is the same also
    I have recently changed both an S3 filter and the TT filter, both let out a woosh as i disconnected the filter, under pressure
  10. Stewart
    Stewart Member
    705
    10
    I would say it depends how long the engine has been turned off as the pressure will bleed away. Thats why the pump primes itself (to pressurise the system) when you turn the ignition on.
    If left overnight you should be fine but take precautions anyway, I.e Wear protective eyewear and something to soak up the fuel should you spill/spray any.
  11. jojo
    28,846
    3,507
    On the subject of fuel filters, how often should they be replaced?
  12. Dave_Bayern
    1,913
    Mine fuel filter wasn't under pressure after approximately ten minutes (oil change time) after switching the engine off.
    Same goes for my friends Mk4 and my girlfriends car too.
    Have other people ACTUALLY observed it being under pressure when replacing it?
  13. Caesium
    4,879
    Yes I have had a face full of petrol spray out and into my eyes, not pleasant
  14. Dave_Bayern
    1,913
    If you clamp the lines, as per ELSA, then you wouldn't see this pressure issue I wouldn't imagine, hence why i have had no problems...
