Not firing after I play my aftermarket sub
jnash123 Oct 18, 2011
  1. jnash123
    jnash123 New Member
    25
    Have a 05 a3 tdi sport, it seems to not start perfectly after I've been playing my music , it works the first time I've started the car in the morning any ideas ?
  2. mike foster
    3,967
    Probably nothing to do with the music.
    Hot starting problems are common on the BKD engine and at that age the most likely cause is a failing starter motor.
  3. akash_sky1
    akash_sky1 Active Member
    1,181
    Could be Sub related actually. What sub /amp are you running OP? If the amp and sub are drawing a lot of current it could be draining the battery, making it harder to start if you turn it off and re-start just after blasting your tunes. However this is only if your running a serious set up like 2500 Watt RMS atleast. Do the lights flicker with the basslines?
  4. marknjayne
    marknjayne Member
    425
  5. xanderxxx
    xanderxxx Active Member
    105
    30
    maybe the car is protesting about your choice of music :) :undwech:
