Not another Nogaro!!!
IanPG Jun 16, 2016
  1. IanPG
    IanPG Well-Known Member Team Nogaro Blue Silver Supporter Audi S3
    1,389
    550
    Not many of these guys down in Australia let alone this colour.
    Just creating a picture thread as I get things nearing completion aesthetically.
    #teamnogaro
    Enjoy
    tcg and dusty like this.
  2. IanPG
    1,389
    550
    Ultra wide angle blue/heated aspherical wing mirrors.
    No second thought on installing these!!!
  3. IanPG
    1,389
    550
    I wanted all black wheel bolt covers but i stuffed up the plastidipping job and it lifted in a couple of sections next to the centre logo.
    So i went to peel it off to start again and ended up with this "mistake"
  4. tcg
    tcg Active Member
    586
    222
    43
    Car looks sweet mate :hi:
  5. IanPG
    1,389
    550
    Why thanks for the hats off sir
  6. IanPG
    1,389
    550
    - was a little icy tonight in Melbourne
    - found me a nice little slip lane (complete with striped ground)
    - top down
    - then old mate Bumblebee comes along
    - calling it a night
    Gonzokew and scotty_24 like this.
  7. IanPG
    1,389
    550
    Just to log my car's work history
    cleaning of the suction pipe
    booooooo standard internals! (at least it's super clean PLUS needed to flush out the semi synthetic that the last owner got his mechanic to put in last the last service ... tsk tsk tsk)
    all gunk removed from sump & looking very fresh
    feck_on_a_stick likes this.
  8. IanPG
    1,389
    550
    had a bit of intermittant coolant leakage... was very weird because it wouldn't happen when the car was running
    turns out it was coming from the after run pump. So i removed the bracket and lifted it out the engine bay. The unit is still in tact and motor is still running so I opened it up and saw
    - it's a big magnet (the rusted looking thing)
    - coolant only runs through the top part of the unit
    - there's an o-ring that was the suspect!
    - there's the o-ring that seals the coolant from leaking! 2mm thick, 23mm ID
    I guess they need changing after a while! Only cost $4AUD
  9. IanPG
    1,389
    550
    Nogz had a bit of a get together with some friends
    14249987_10208561131078671_5837866185235946556_o.jpg 14225388_10154498518510148_7231496577043102899_n.jpg 14232430_10154498518670148_884404843654532931_n.jpg 14241661_10208561133318727_7118033039467388869_o.jpg 14258114_10208561130158648_9143290967369748211_o.jpg 14289934_10208561142678961_5799268085123177580_o.jpg 14305363_10208561137398829_827808015356090094_o.jpg 14231915_704291139721317_501822866609690646_o.jpg
  10. Roadtrain
    Roadtrain Audi S3 8L 225 "BAM" from Italy :)
    224
    32
    IanPG likes this.
  11. Stuart B
    Stuart B Well-Known Member
    2,052
    375
    Hi, So for me - this device is regularly running when the engine isn't - and earlier today when I was adjusting my headlights with ignition on, it started running (albeit a bit weakly) even though the engine had not even been started for 3 days? I have in the past unplugged it thinking it would flatten the battery as it was running for ages. Is this something I should consider servicing in the same fashion as you have?
  12. IanPG
    1,389
    550
    It was a great night out! Small but mighty crowd :)
    I serviced my o-ring because it was leaking. Does yours leak?
    This pump is supposed to run for ~10 minutes when you turn the ignition on and then run for about 10 minutes after ignition off. I believe it feeds coolant to the turbo pre and post engine running to ensure better cooling of it and protection. Sounds like you have nothing to worry about. If you are concerned maybe check to see if it is turning off after 10 minutes? Flick ignition to on, after run pump should go, read a book or catch some Pokemon for about 10 minutes and come back to see if it is still running or has turned off. Should be off (or wait another couple minutes and it should turn off)
    Roadtrain likes this.
  13. Stuart B
    2,052
    375
    arh okay thanks - that sounds about right - the reason I didn't think it was cooling the turbo as someone said something about this type of thing not being allowed maybe it was that the turbo isn't allowed to continue to run without the engine running but the water circulating is allowed? this must be why it is both oil and water cooled.
  14. Roadtrain
    224
    32
    Do you have original turbo K04 or different one?
  15. IanPG
    1,389
    550
    It is kind of like a turbo timer (illegal in Australia too) but I think with turbo timers the engine is still running? With this it is engine off - only the pump is running
  16. Stuart B
    2,052
    375
    A wreck of an original K04
    oh I see - yes that was what I was thinking of which are not allowed.
    IanPG likes this.
  17. Roadtrain
    224
    32
    Sorry I'm not so good in english: dictionary sayed "wreck --> relict"?
  18. IanPG
    1,389
    550
    wreck = from a crashed car or a car at a junkyard or a parts car
  19. Roadtrain
    224
    32
    OK thank you :)
  20. Stuart B
    2,052
    375
    its a "wreck" because it has a cracked hotside and the coldside turbo wheel has a little in / out movement - I cleaned the hot side with Mr Muscle when replacing head gasket and adding the 3inch downpipe. I was tempted to get a service kit but you have to remove the turbo to fit it and then adjust the actuator properly and replace all the oil feed lines. then if you do all that you may as well replace the turbo in its entirety but if you do that you need to change the oil pump and oil pick up, but to do that I need to take the sump off and to do that I will need to drill off those 3 impossible to reach and always rounded off and seized sump bolts, but if I took the sump off with the head also off I may as well change the rods and if I do that I may as well get new pistons and a rebore etc
    he swallowed a spider to catch the fly...
    its easier to just admit the turbo is a wreck :D
    Tj 0785, Roadtrain and IanPG like this.
  21. IanPG
    1,389
    550
    HAHAHAHAHAHHA
    omg that was like over catasrophising to the max!!! It is a slippery slope and sometimes you just gotta bite the bullet ;)
    you can always get a service kit as long as the wheels haven't been damaged... which it sounds maybe it has as i understand it the k04 shouldn't have any in/out movement. sure the turbine cannot be as shagged as this
    look at the inducer depth...
    look at it there... ummm... oops!???
    But yeah i guess to do it PROPERLY it is recommended to replace the lines. I did have a go at this myself - you find "tricks" to accessing the bolts and nuts that you need to without having to fully remove everything!!!
  22. <tuffty/>
    21,955
    4,229
    Turbo timers are illegal in the UK as they keep the engine running unattended to 'cool down' the engine/turbo... the after run pumps doesn't require the engine to be running and circulate coolant through the turbo to help cool it down
    IanPG likes this.
  23. tcg
    tcg Active Member
    586
    222
    43
    I don't think they are illegal as such,but it is illegal to leave your car with the engine running,unattended.I had one fitted to my last car and had no problems but I always sat in the car until it switched off.
  24. <tuffty/>
    21,955
    4,229
    semantics... buying and owning one is not illegal... using one in this manor commits an offence
  25. tcg
    tcg Active Member
    586
    222
    43
    Guilty as charged :blush:
  26. Roadtrain
    224
    32
    I think I understand now, thank you ;)
  27. Roadtrain
    224
    32
    Italian tyres :) "Cinturato" means bies belted in italian, did you choose it because you need strong sidewall? If yes, Bridgestone Potenza S001 are very strong aswell :)
    PS:
    What brakes type did you adopted? I need change discs and pads sure, but it's a good opportunity to change calibers and hoses too. Thank you.
  28. IanPG
    1,389
    550
    I have the Porsche 986 4-pot brakes on the front :)
    Maybe you have plenty of those "wrecking" in Italia - could be a very good/cheap option for you especially if you are thinking of more power in the future.
  29. Roadtrain
    224
    32
    Thank you a lot :) So Porsche 986 4-pot brakes are the best choice?
  30. IanPG
    1,389
    550
    Orange225 and Roadtrain like this.
  31. Roadtrain
    224
    32
    No I didn't, thank you about link :)
    IanPG likes this.
  32. IanPG
    1,389
    550
    stripping an AGU head - bit fiddly
    trying to be organised LOL
    no bends so far
    Roadtrain and S3 Hilife like this.
  33. IanPG
    1,389
    550
    All valves out, removed seals and spark plugs. Head off for a pressure test *fingers crossed* hope all goes well
  34. Roadtrain
    224
    32
    Hi Ian, why would you use an AGU's head? That engine has 150 PS only, right?
  35. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    The engines output isn't governed by its cylinder head.
    The AGU is largeport
  36. IanPG
    1,389
    550
    head has checked in as good and usable (can't believe how much **** was on there)
    - next step... valve guides - so i am seeing two part numbers which is annoying
    058103415 and 058103419
    same same but different?
    what about stock VS IE ones?
    I was looking at the supertech ones but have been informed that they are shorter hence won't give the valve as much support so would probably need servicing after 50,000k's rather than the stock option that would be good for another 100,000k's
    opinions please?
  37. IanPG
    1,389
    550
    the heads are interchangeable with the 1.8t's and the large port (VS the small port on BAM/AMK) allows for better flow for bigger than k04 turbos
    Info and pictures on large vs small port
  38. Roadtrain
    224
    32
    Thank you very much both, I didn't know about this. I don't understand why BAM has large valve intake instead AGU has small one, I would bet on opposite choice before read your post.
  39. IanPG
    1,389
    550
    Other way around :)
    BAM/AMK is the small port intake
  40. Roadtrain
    224
    32
