Noob Xenon question
AndyParker Oct 10, 2012
  1. AndyParker
    AndyParker Active Member
    320
    Hi guys - apologies for the noob question but was there a point when Xenons became standard equipment on the 8p S3 or have they always been optional?
    Is there an easy way to tell if a car has them? The headlight washer perhaps?
  2. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    570
    154
    43
    My Black Edition has Xenons as standard with the LED "frowning" DRL's. I think you are correct about the washer units and also when unlit you can see the way the lamp is made wether it has the LED section along the top edge or the light bulbs DRL's at the bottom. also with Audi xenons they will have have auto levelling so next to the light switch inside there shouldn't be a height adjuster switch.
  3. AndyParker
    320
    Thanks Helifella
    i'm conscious that the LED DRL's only came into play on '58 plate and onwards (?), what's the score with the none LED DRL Xenons if there is such a thing?
  4. Helifella
    570
    154
    43
    They might be out there but i'm less than a year into the brand so not really qualified to say :)
  5. AndyParker
    320
    No problems :) you're further into it than I am so appreciate your help!
  6. AndyParker
    320
    Maybe a photo will help - are these Xenons?
  7. Matty-m
    Matty-m New Member
    Yes they are xenons with non led drl lights
  8. Cossie_boy
    Cossie_boy Member
    472
    On the whole Xenons are like rocking horse **** on the A3's, hence why its taken me a stupid amount of time to find the right car as they were no1 on the list, but yes, as said, the photo is correct and they came with the washers as standard
  9. AndyParker
    320
    Thanks Guys - most helpful!
  10. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Open the bonnet. Look beside the headlight unit. If xenon there will be a box like thing the wiring looms plug into, plus a warning sticker of HIGH VOLTAGES. Plus they have the typical audi part number on the box.
    Most likely the pic is of a xenon unit but than again my TT has projector lamps likes these and washer cut outs in the bumper, but it's fitted with standard halogen lamps.
  11. bmh.01
    bmh.01 Member
    291
    17
    Xenons have always been standard on the S3. Xenons and Climate are two of the very few things that are.
  12. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Quickest way is to look at the light switch - no thumb wheel next to the switch if xenon - because they are auto-level
  13. Cossie_boy
    Cossie_boy Member
    472
    Hmmm thats a bloody good point, the other day I met with another forum member and he pointed out that my car, which has adapitive Xenon plus, should as standard have auto and get me home lights, it does not :/ and also im sure next to the DRL switch it has a light leveller...
    Before I even went and saw the car I called Audi and they listed the factory extras, it was a long list, but they said adative Xenons, im not feeling a little concerned as to why it doesnt have the auto/get me home lights, and, may have a level adjuster, its in the garage again so I cant go and check but this has got me thinking!
