none start a4 1.6
skelly Feb 25, 2010
  1. skelly
    skelly New Member
    just wondering if any 1 can help me
    just brought an a4 1.6 with a sezeed engine
    so replaced engine but wont start
    i have spark and fuel up 2 rail and compression is good
    car will run on carb cleaner fine so i have put it down to injectors no reseiving a signal
    have change crank sensor,dizzy (hall sensor) fuel rail and injectors
    can any1 help as i am puzzled as why it wont run
    thanks Skelly
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,000
    764
    Did you change the ECU, does the car start then stop after a second?
    Also do you have vag-com, to check for faults?
  3. skelly
    skelly New Member
    no i didnt change ecu just got an engine and used just the block and head everythimg else is what was on car
    no dosent start then cut out just wont start at all. only runs on cerb cleaner and sweet at that
    gonna scam it with an omitec 2morrow
    eml goes off
    so does the transponder light
