Non turbo FSI crankshaft good for stroker build?
Scullies Mar 11, 2013
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    As above I was wondering if a n/a 2.0 FSI crankshaft would be suitable. All the info on stoker builds are referring to TFSI cranks. Not sure if there is a difference between FSI and TFSI crankshafts. The crank I have found doesn't look the same as the TFSI I had before. It's looks more like the 2.0 8v crank used in the mk4 engines, so I am assuming its cast.
  2. Andrew@A.L.D
    3,877
    617
    Mines cast and its still mint, the yanks are running cast cranks with a hell of a lot more power than me. I will get the engine codes of cranks you can run for a stroker .
  3. Scullies
    1,543
    657
    Thanks Andrew,
    I see the Yanks go on about the AEG crank! Do you know what is so special about that crank. As far as I can see all 2.0 8v and 2.0 fsi cranks should be a drop in crank for a 2.0 stroker, excluding the oil pump drive gear on fsi crank.
  4. Scullies
    1,543
    657
    I think I found your list on vortex :arco:
    VWVortex.com - 2.0 stroker crankshaft options
    this makes my life easy now, there are so many mk4 engines in the scrap yards here. 2.0 8v and 1.8 20v. They get cut out cars in Japan and shipped over by the container loads!
  5. Andrew@A.L.D
    3,877
    617
