non-ESP old TIP, anyone got one they can send me?
badger5 Feb 1, 2011
  1. badger5
    9,507
    2,003
    Hi
    Has anyone got an old non-ESP TIP, anyone got one they can send me?
    (for making a 3inch version from hopefully)
    thanks
    bill
  2. Dani_B19
    9,321
    390
    For the APY engines bill? If so, the esp tips fit fine, the only difference is you need to use abit of vacuum pipe for the n75 to reach the other side.
    Your 3" tips should fit fine, i plan to get one after my service in feb :).
  3. badger5
    9,507
    2,003
    hmm, really?
    not seen one here to have a good look.
    I have a lhd S3 without esp, and his fitment of the existing 3inch tip is not fitting.
    I am trying to see what I would need to do... its more angled at the bottom, bends twice before rising up.. LHD car having brake servo in the way... so not sure if the issue is entirely non-esp or lhd & non-sep
  4. Dani_B19
    9,321
    390
    Have a look on build thread bill, it shows pics of what a non-esp tip looks like, its got a double bend at the botton of the tip before it goes into the turbo, it's quite flat and very restrictive.
    You would need to change anything on your 3" tip, like i said, i fitted a SFS silicone tip to my non-esp s3 (v reg) and all i had todo was extend the n75 vacuum hose as the electrical connection wouldnt stretch that far, also the pcv hose would need exteneding but thats it, a case of some silicone and you'll be fine :).
  5. <tuffty/>
    21,367
    3,932
  6. jojo
    28,908
    3,564
    I will need one of these 3" for my early APY in the near future, and most probably get you to fit one for me Bill.
  7. Dani_B19
    9,321
    390
    Yeah that's the one paul. Been on hold since the 2 crashes back in 2009 :(, will be starting back up this month though :), watch that space.
  8. <tuffty/>
    21,367
    3,932
    Bring it along one weekend Jo...
  9. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i have one, my car has no esp but thats an a3 with a k03 so probably not much help.
  10. badger5
    9,507
    2,003
    I have a european customer in sweden and his is'nt fitting, but he also has non-esp and brake servo to contend with...
  11. Dani_B19
    9,321
    390
    There wasnt a brake servo in the way on mine, got to be down to his been LHD.
  12. metricspaces
    metricspaces Member
    661
    I'm interested in this TIP (and large cone!) for APY non-esp also!
    Just unsure about what I would need to get done to the map and whether this can be done by myself with something like CustomSettings (I have a CustomCode Stage 1 map).
    Like is it a simple case of just changing a value in the map to some standard value? Or I'd need to bring the car to a tuner with a rolling road to sort this out? From the other thread on this there's this bit of info http://www.audi-sport.net/vb/a3-s3-...h-tip-tests-danes-s3-today-2.html#post1148366
    "it needs logging with wideband on dyno... 5% on wellys, but his is hybrid turbo and was hi-flow mani as well as 3inch tip also.. "
    So it sounds like I would need to get the car to someone with a dyno who can also tweak the map? Is this correct?
  13. badger5
    9,507
    2,003
    no changes done at all to Danes - not required.
    Wellys I added some fueling with unisettings after logging it with my dyno/wideband, BUT, his was hybrid and a lot more flow.
    Not needed by others so far.. non wideband cars, initial fueling is load based off airflow... more air, more fuel (stock k04)
  14. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Bill do you still need a tip?
    Just removing the turbo off my latest project to get it refurbed and as such the tip is just sitting on my work bench if it's any help you can borrow it for a week as long as I get it back :) Let me know
  15. badger5
    9,507
    2,003
    yes please.. non esp one yea?
  16. motfree
    motfree Member
    464
    Count me in !! When they available ??
  17. Ginge
    Ginge It's never fast enough !
    192
    Ha I'll be having one too if/when it's done :)
  18. beachbuggy
    1,931
    201
    Almost certain it's a non esp. it's a 1999 APY but will double check for you. If so shall I just send it to you at Badger 5?
  19. badger5
    9,507
    2,003
    take a picture of it to confirm if you like.
    address to send I'll pm you.
    thanks
  20. Dani_B19
    9,321
    390
    Simplier way, do you have a esp button on your dash, if yes then you dont have a non-esp tip like what i had.
  21. beachbuggy
    1,931
    201
    Thanks but I kinda of guessed that.:).. the only reason I'm not sure is that I bought it with no engine as a project, and as such never actually sat in it to drive so couldn't tell what's on the dash but pretty sure the 1999 apy's where non esp, so am confident it wont have ESP but will chk anyway
  22. metricspaces
    metricspaces Member
    661
    Just wondering, is there any danger with this increase in flow on a stage one map?
    I remember there was a guy on here maybe a year ago, who I think was on stage one from JBS, then he changed his down pipe without modifying the map...and ended up in a bit of a disaster. I can't remember the exact problem, but something along the lines of the increased flow just caused everything to overheat.
  23. Dani_B19
    9,321
    390
    Esp on APY engines was a optional extra, only when the AMK/BAM engines came out was it standard fit.
  24. badger5
    9,507
    2,003
    nope.
    more airflow more fuel on intake and wideband cars control their own fueling
    if in doubt on non-wideband cars, take it to a dyno to get afr's logged
  25. Broken Byzan
    13,237
    465
    I have an A4 TQS one here !!! ;-)
  26. badger5
    9,507
    2,003
    I cant hear you .... :)
  27. metricspaces
    metricspaces Member
    661
    Thanks Bill. So would I be correct in summarising that the general message for us S3's owners that are APY non-esp & non-wideband, is that we can stick on the 3' TIP and larger cone filter without needing to change the map. We should see roughly an increase from about 250bhp to 270bhp if we are on stage one, and we shouldn't see any problems with fueling?
    If we were to see any problems, in laymans terms :) what problems would we see and what would need doing rectify the problem? Is it just that non-wideband cars may not be getting enough fuel to match the increased air and the map needs to be updated to add more fuel? What would happen if enough fuel was not being provided?
    What are afr's? Will we be able to do some logging in VAG-COM to make sure that everything is ok, rather than putting it on a dyno?
    What's the difference between wideband and non-wideband? From message I read, I thought it meant cars with wideband would adjust their fuel to match the airflow. But you mentioned earlier that on non-wideband cars, initial fueling is load based off airflow... more air, more fuel (stock k04) - so that sounds like non-wideband cars also adjust fueling based on airflow? Confused now!
  28. Broken Byzan
    13,237
    465
    That's your age matey ;-P
    Will pop over at some point, its possible some of what you have can be adapted etc assuming my car comes back working.
    What's the ID on the turbo bushes you had made?
  29. metricspaces
    metricspaces Member
    661
    Bill, any info on my post here? I think this would be useful info for any of us looking to go with your new TIP. Cheers.
