Noisy Fuel Pump
spiker Dec 4, 2009
  1. spiker
    spiker usually growling at something
    200
    HI all
    Had the fuel pump replaced on my 2002 s3 after it starting making 'whiney' noises
    The replacement has subsequently started doing the same
    I am getting 44mpg ( YES 44mpg) so clearly underfueling
    Maf has been changed
    Any suggestions - Awesome have suggested its nothing to do with the pump but what else could have caused this to fail as it appears to have happened again
    Could this have been caused by fuel tank contamination ?
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    I'm guessing you've changed the fuel filter and slapped some Redex/STP/Forte/any other brand fuel system cleaner through it?
  3. spiker
    200
    Fuel filter ? just curious as to how that would help if the noise is coming from the pump itself
  4. Welly
    10,696
    127
    If the filter is blocked then it would stop fuel getting to the engine in correct amounts - causing your 44 MPG...
    Also, if the pump is having to work twice as hard to force the fuel through at all, it may well whine. Another explanation is that the sound is pressure forcing it's way back through the pump due to a blockage.
    I'd definitely change it, they're about 8 quid from a motor factors and should be changed regularly anyway to be fair.
    If you've had the pump changed and are getting the same symptoms then it's unlikely to be the pump i'd say.
    So fuel filter would be the first place I'd start...
  5. Welly
    10,696
    127
  6. Westy
    Westy Well-Known Member
    17,442
    1,100
    I'm doing my fuel filter this weekend. My mate at work has an S3 and his filter was the original one from when the car came out the factory in 2002! It was so blocked it had split and was pissing fuel out everywhere.
    Spoke to Audi and they dont even change it or sell the part! You have to buy the part from an independant parts place as its a bosch part.
    I'm going to ensure that mine gets changed with every major service from now on.
  7. Welly
    10,696
    127
    I always change mine on a service, only after having a blockage myself though - like you said they get so full up with swarf and bits they just don't do what they should after a while!!
    I like to run fuel system cleaner too funds dependent!! But the filter, all be it a pain to change (getting covered in fuel due to the fact I'm too much of a skin flint to buy fuel line clamps), for the sake of a few quid, it's well worth doing.
  8. spiker
    200
    Ok thanks
    I will get the filter replaced - it cant do any harm i suppose
    Thanks for the input - I will let you know how i get on
  9. Welly
    10,696
    127
    Cool cool, nothing to lose by doing it, good for general mainenance if nothing else.
    Hopefully will sort your issue out :)
  10. spiker
    200
    Filter ordered
    Where is it located ? Do I need to use fuel clamps ?
  11. Westy
    17,442
    1,100
    It's in front of the rear wheel on the drivers side under the side skirt.
    Take out fuse 28 then turn the car on, it will stall after a few seconds without the fuse for the fuel pump. Open the fuel filler cap to de pressurise the system then you can remove the filter. You can do it without clamps but expect a tiny amount of fuel to come out so use a washing up bowl or bucket to collect it.
  12. spiker
    200
  13. spiker
    200
    Well I have changed the fuel filter - no improvement
    Its been suggested I might take a look at the Fuel pump regulator - is this something that is prone to issues ? and has anyone here changed one ?
