noise when starting
basim Feb 27, 2014
  1. basim
    basim New Member
    Hi,
    I have a new A3 sportback that started making grinding metal on metal noise when reversing and setting off every morning within a week after purchase.This noise disappears later on.I took it back the dealer who kept overnight had a look and said this is normal.However I have never had this noise in any of the cars I bought in the past and certainly not in the courtesy car . It is loud enough in the morning that my family and next door neighbour can hear from inside.I said this to the dealer but he said what he has heard is normal.
    I am worried this could be a start of a major fault in the car.
    Has anyone experienced this?
    Can anyone advise please?
  2. MorkC68
    MorkC68 Stationary
    171
    27
    Metal on metal grinding noises are far from normal - I'd suggest taking it to an Audi specialist for a second opinion!
  3. s3tommy
    s3tommy Member
    39
    possibly a sticky starter motor not disengauging
  4. SmithyAG
    SmithyAG Active Member
    414
    61
    Metal on metal does sound like flywheel/starter issue.
    Is it when starting the car or reversing/setting off in 1st, as the title and the OP say different. If when starting then possibly starter motor, if when engaging gears it could be flywheel, unless it is only certain gears, in which case it could be gearbox, synchros and the such.
  5. basim
    basim New Member
    Hi,
    I start the car and the noise appears as I reverse to come off the drive into the road then disppears later .i.e even when I start and reverse when I am at work or at the shop after half an hour. It happens every morning .Thanks
  6. SmithyAG
    414
    61
    If it's only when you are moving the car from stationary, I would bet on gearbox/synchros/CV joint.
  7. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Bake discs...... Perhaps pads sticking a little. May disappear with use / normal wear.
  8. basim
    basim New Member
    The noise is with reversing before I use the brakes to stop the car at the end .
  9. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Basim, do you set the handbrake on after stopping in the driveway? If so, I would suggest you try to leave it off overnight, with the gearbox engaged (and a brick behind a back wheel). If the noise disappears, it will be the handbrake mechanism not releasing the pads properly, or a pad sticking on the disk. Just an idea.
  10. MrLapou
    1,233
    121
    Like I said brakes binding. As above leave handbrake off and car in gear or Park.
  11. SmithyAG
    414
    61
    Definitely check brakes first, far cheaper fix than gearbox etc!
  12. Artimus
    Artimus Shortback
    2,016
    485
    It's not normal, so have the garage fix it or refund your money.
