Noise when on boost :S.
cawsey20 May 26, 2010
  1. cawsey20
    cawsey20 Member
    150
    Right , Ive searched around abit obviously boost leak may be the answer however,
    Driving home from work today was fine all well and good i was granny driving anyway. Then i got home and took my friend for a spin as he hadn't been in my s3 before.
    On full boost i heard a noise that can only be described as a prelonged beep :S, It sounded almost electrical but quite high pitched :S.
    It only does it under full boost just strikes me as odd . Any suggestions.
  2. OllieH
    OllieH Member
    368
    If it's a high pitched squeel only when on full boost it's likely to be turbulent air in the TIP. Is your car mapped as this is very common on mapped cars? If it was a boost leak you would most likely hear it at other times aswell, not just full boost. When I bought my S3 I heard this noise and thought it was a belt slipping, but found out otherwise. I have since fitted a silicon TIP and it has gone.
  3. cawsey20
    cawsey20 Member
    150
  4. cawsey20
    cawsey20 Member
    150
    And yes mate , its mapped its been mapped for about 3 weeks an the noise only started today :S
  5. OllieH
    OllieH Member
    368
    Difficult one that. Does sound different to what mine sounded like. Almost like a whistle blowing, which could lean to a boost leak.
  6. cawsey20
    cawsey20 Member
    150
    Yer it sounds like a beep aswell its so random :S.
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    That is what I like to call a 'squeeler'. A boost leak mate, without doubt. Its as the turbo comes on full chat.
    That sound is normally made by a jubliee clip on the pipework not being tight. Check ALL the clips. Including the one from the turbo to the red pipe.
    Also, when looking, keep an eye out for any joins which are a bit damp, this is normally a good indication.
  8. Westy
    Westy Well-Known Member
    17,443
    1,105
    Could be a leak around the TIP. A standard TIP tends to collapse on full boost which might be creating a slight gap where it is jubilee'd.
  9. Welly
    10,696
    129
    Whilst this is true, the sound you can hear is the result of pressure escaping. That's why it's such a high pitched squeak.
    The TIP never sees any pressure, it only ever sees vacuum, which wouldn't produce the sound of pressure releasing. This says to me that it's likely to be in the charge system somewhere.
    The TIP cavitating under vacuum does make a sound, but not that sort of sound.
  10. Westy
    17,443
    1,105
    I probably should have listen to the noise first shouldn't I :whip:
  11. Welly
    10,696
    129
    LOL, it's OK dude. :thumbsup:
