Noise from rear ??
Bradderz_1988 Nov 20, 2010
  1. Bradderz_1988
    3,980
    261
    It's sounds like rear diff mounts basicly when am letting on and off the accelerator pedal it's thudding from the rear ??? any suggestions ???
  2. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Get some sikaflex 252 in the bushes. Not had a sound from mine since. Or buy a mount from 034.
  3. Bradderz_1988
    3,980
    261
    Ok weres that available from ??? It's only started doing it since I had it up on the ramp at work this morning every thing seem'd to be ok must just be sods law that it decided to start thudding when I got my hopes up there was nothing wrong typical ha
  4. phoenixv6quattro
    1,396
    You can get sikaflex 252 from most online hardware stores. Its just polyurethane in a tube. The performance mount/bush can be found on 034 motorsports website. Costly though and from the states.
  5. Bradderz_1988
    3,980
    261
    Checked the thudding noise it wasn't the bushes I'd some how with my lead foot managed to work the 3 8mm hex bolts at rear of diff loose which is a bonus bit aid loctite and it's gone :) !!
  6. pjw
    pjw Member Audi A4
    222
    Result - ive got sikaflex, its the shizzle. One tube has lasted me years, just dont get it on paintwork ever as it wont come off..
  7. aragorn
    18,577
    868
    Years? i always find it goes off once opened if left for any length of time.
  8. Bradderz_1988
    3,980
    261
    Going to get the sikaflex I think just to prolong the bushes and cut some slack, can I basicly do every mount on the car with this stuff and how long does it take to go off roughly and do I have to remove the bushes or just lower them to get the sikaflex in ??
  9. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    you can fill both diff and both gearbox mounts, then get a poly front snub mount
    ideally you want to get some spare mounts as even the fast cure sika takes a few days to harden and the main diff mount needs doing in layers or middle will never set
    well worth doing though
