Noise coming from Gearbox ????
a3james May 21, 2012
  1. a3james
    a3james Member
    Hi All
    Ive got a new problem this time :(
    Its a Audi A3 2.0 TDI S Line BKD With DSG 2005
    The dual mass flywheel has just been replaced and the problem still occurs with the scrapping sound. but the juddering noise has been eliminated when it was in neutral :)
    When im driving when i floor it in first to second or second to third gear it sometimes judders like its wheel spinning but its not. also when im down the motorway it makes a scrapping noise at certain speeds ? its only started doing this since ive had the head changed though.
    Im probably gonna get it booked in for a DSG oil and filter change and see what happens.
    So if anyone could give me any advise that would be great :)
  2. a3james
    a3james Member
    Has anyone got any info or suggestions ?
    Much appreciated
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Was the clutch replaced as well as the DMF?
  4. a3james
    a3james Member
    no it wasn't as the clutch is inside the gearbox and for the update the oil and filter has seemed to sort the problem.
  5. alastair0903
    alastair0903 New Member
    22
    good to hear that you have sorted this , mine sounds exactly the same as yours . i will have to get a flywheel, oil and a filter .
    did yours also seem a little jerky going from 3rd to 2nd gear ?
    thanks Alastair
  6. Lee_C1
    Lee_C1 New Member
    12
    I have a similar issue with my 06 2.0tdi DSG, when it up shifts 2-3 and 3-4 there is slight judder just before the shift happens, usually at between 3800 and 4000 rpm, if I understand these posts it seems to be fixed by oil and filter change as well as dual mass flywheel? How much is this?
