Noise after ignition turned off
MrTackalakalaka Apr 4, 2012
  1. When I first got my S3 I remember there used to be a humming/buzzing noise for a few minutes after I turned the ignition off and then it would cut out.
    Ive just noticed that it doesnt do this anymore. I don't know how long it's been like that.
    Anyone know what that noise was?
    (was coming from the engine bay)
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    After run pump for the turbo and a common failure....
  3. Does it cool it down or something and is it an expensive job?
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,244
    349
    MrTackalakalaka likes this.
  5. Poke13
    Poke13 Member
    157
    Don't mean to Hi-jack but I have noticed a noise after ignition turn off on my S3 recently and I have to re-start and turn off to get it to stop.
    Here's a vid of the noise:
    Do we reckon this is the after run pump too?
    Do these cars have the fans that run after ignition turn off if engine is hot as I have never heard mine running a fan after ignition is turned off?
    (Will post up a new thread if people think it's needed).
    Jonny/Poke13
  6. s3dave
    10,110
    736
    Yes that is your afterun pump..
  7. Poke13
    Poke13 Member
    157
    So does this mean it is broken/on the way out? It doesn't do it everytime I turn ignition off.
  8. S3Zek
    S3Zek Member
    410
    When you turn it off, sounds like its on it's way out to or the conetcion is dirty, next time you turn it off give the moter a tap or wigel the plug and see if it changes pitch
  9. Poke13
    Poke13 Member
    157
    Right I will have to look into this! Thanks!
    Any ideas on price of one of these units and where to get one from TPS/Audi?
  10. Was trying to remember when the last time I heard the pump working and I'm pretty sure it was when my aircon was still working.
    Is the air con linked with it at all? The button works but just no cold air comes out.
    Had a look at the pump earlier and it looks in good condition all around and no signs or corrosion or anything
  11. beachbuggy
    beachbuggy Well-Known Member
    1,931
    200
    Have you checked the green fuse on top of the battery? I think it's the left hand one of the 3 ( possibly 2) if thats blown the overrun pump stops.
  12. Ah just looked at all 3 the one on the left looks like it may have blown! Fingers crossed that's it! Thanks man!
  13. After replacing the fuse that had quite a bit of black/grey build up on it i drove over to my local skatepark........turned the ignition off and then could hear the pump working!! Bonus!......Drove home later on and it worked again! think it just had a dodgy connection. Will get a new fuse anyway and clean out the connection on the battery bit
  14. Eddie S3
    Eddie S3 Member
    128
    9
    How long is the after run supposed to stay on for?
    Mine sometimes on on for 10+ minutes, and thats only from a 4mile drive
  15. <tuffty/>
    20,797
    3,662
    Its around the 10min mark...
