No Windows?
sorted Dec 17, 2012
  1. sorted
    sorted New Member
    25
    * No windows work with switches
    * No windows work when hold unlock button on key
    * No windows work when hold unlock over on the door lock
    * Lights on the drivers door dont light up switches etc, and controller for the wing mirrors doesnt work?
    * Checked the fuses in panel side of dash for blown, none - ended up checking every fuse
    Is there any other fuses to check, any relays? Could a wire break casue this? I though the passenger window would still work with its switch?
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    sounds like a comfort control module error, is your passenger side footwell wet ?
  3. tommytonguedj
    tommytonguedj Member
    133
    Mine done the exact same a few month back for some strange reason the plug behind the drivers door card had unplugged. hth
  4. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Get it scanned, might show something up/pinpoint a problem .Save the guesswork.
  5. sorted
    sorted New Member
    25
    Have vag com and scanned, got no errors. Thats what led me down the relay/fuse route/wires. No wetness at passenger side!
  6. sorted
    sorted New Member
    25
    Was this stopping the passenger door switch from working aswell? Thats really throwing me!
  7. marktdisport
    marktdisport Active Member
    1,195
    15
    I'd say your door wiring is broken whitin the door loom inside the rubber boot my passenger side stopped working aswell......
  8. dale86
    dale86 Member
    452
    15
    Definately door wiring broke mine did the same speakers also stopped working and mirrors common problem.
  9. andyw82
    andyw82 Member
    46
    mine stopped after i had a leak there is a fuse up from under the dash, u have to take bottom of dash under steering wheel off there is a few its the 1 on the right that goes up and down. mine had corroded and broke change it and all was good again.
