No Water
N80KRR Aug 5, 2009
  1. N80KRR
    N80KRR Member
    180
    Well, looked this am no water in car. but I only filled it up a week ago. Not done thousands of miles. So whats happening? I've checked the tank and pipes they're all dry so no leaks that I can see. Anyone had same issues?
  2. docurley
    4,073
    88
    check the oil and make sure its not brown.
  3. N80KRR
    N80KRR Member
    180
    It's very dirty brown, it was supposed to be replaced when it was serviced back in march. Guess it wasn't. Does that mean I need to change it ASAP?
  4. docurley
    4,073
    88
    I meant like a creamy brown colour
  5. N80KRR
    N80KRR Member
    180
    nope just like dirty oil. So could do with a fresh change really.
  6. docurley
    4,073
    88
    Well oil gets dirty looking quick so may be not.
    Now your problem, well so far it does not sound like the headgasket so I would refill and run the car looking for leeks checking the header tank for a start.
  7. N80KRR
    N80KRR Member
    180
    sorry not very mechanically minded, looked at the water tank and pipes that lead off it to radiator. everything seems to be in order. no leaks that I can see or feel.
  8. docurley
    4,073
    88
    Some times the bottle spits on the joint and will only leek when the water gets hot and the pressure builds.
    Look for any signs of a sort of reddish dye or rust this may indicate where the water might be coming from.
  9. Xmay4444
    Xmay4444 On Point!!
    258
  10. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Same problem on my S4 cab - it was the auxillary rads behind the headlights. THey have a tendancy to leak very badly after a few years. Known issue. Good luck.
  11. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
