No warning beep when lights left on?
Quattro180 May 11, 2012
  1. Quattro180
    Quattro180 Member
    99
    I recently realised that me & the mrs have been leaving the headlights on because the warning beep has stopped working. The warning beep for low fuel & other warnings also no longer works.
    The beep always used to work? Is this just a case of the beeper broken or something else?
    cheers
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    does your dis display the door open on the drivers side ??? if not you need to check the wiring inside the rubber boot between the door pillow and the door frame quite common for the door wiring to break...
  3. swarcup
    swarcup Well-Known Member
    1,326
    40
    How would that stop the low fuel warning etc from working?
    the buzzer will have most likely packed up and it is located on the rear of the instrument cluster, i dont know of anyone yet who has changed it sucsessfuly.
    Like you mine has done the same i am waiting for a cheap donor cluster to attempt a change
  4. Quattro180
    Quattro180 Member
    99
    Sounds like its packed up!! The dis still displays that the door opens.
    What a pain in the arse!!
  5. marktdisport
    1,195
    15
    sorry my mistake i must not of read it correctly
