No temp gauage movement after EGR Delete - Normal??
ruffrida Jul 17, 2012
  1. ruffrida
    ruffrida Well-Known Member
    1,930
    313
    To add to the small amount of problems i am having with my 19.tdi (110) i discovered another last night, but i am sure i have read somewhere this is normal.
    Since blanking off my EGR i have noticed the temp gauge does not move, alright it has not exactly been warm up norf, but surely it must move a little.
    Is this normal ???
  2. aragorn
    18,605
    871
    did it always used to climb to 90c and stay there?
    If not, you'll likely need a new thermostat.
  3. ruffrida
    1,930
    313
    Yeh it would always get to 90c then drop back to 60c depending on conditions, but was always around the 90c mark.
    Could this cause my limpmode?
  4. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    if your temp is dropping from running temp, surely a new thermostat or a temp sensor would sort that out.
    have you scanned the car with vagcom to see if there are any faults.
  5. aragorn
    18,605
    871
    Fit a new thermostat and see how things go. Your sensor is probably fine.
  6. ruffrida
    1,930
    313
    It does not move from 60c, not had chance to scan it as my mate is waiting for his new lead to come
    Ordered Thermostat - £6.50 GSF Parts
  7. Sevv
    Sevv Pushing the limits..
    1,324
    120
    mate as the guys told you its 99% your thermostat or that temp sensor... the temp sensor is an easy fit .. the thermostat change is a pain but can be done in 30mins with the right tools and is fiddly.. i think we have a how to some where on the forum or stickies.
  8. ruffrida
    1,930
    313
    Nice 1 Sevv, wioll have a look for the sticky now
  9. aragorn
    18,605
    871
    Everyone fits a new sensor because its easier, personally i've never had a sensor fail, but i've had numerous thermostats die.
    The stat is also cheaper, so do that first!
  10. Sevv
    1,324
    120
  11. ruffrida
    1,930
    313
    Nice 1 fella, just spent 15 mins looking for this, lol, let ya know how i get on
  12. Sevv
    1,324
    120
    sure no worries mate, im sure everyone on here will be happy to help.
  13. ruffrida
    1,930
    313
    Fecking typical!!
    Was out in me car for about 5 hours yesterday (in the warm northern sun) and guess what!
    I sat in traffic and the temp gauge came upto 90c, then couple of mins later, fans kicked in back down to 60c again
  14. jamieA3
    jamieA3 Member
    150
    you may aswell order a new dipstick guide now aswell as it WILL break. ( unless you have child hands )
  15. ruffrida
    1,930
    313
    I take it this has to be removed then?
    Defo no childs hands here, going have to be careful
  16. jamieA3
    jamieA3 Member
    150
    the trouble is that its so brittle. you will see what i mean when you change the stat. a replacment from ebay costs 3.10 and took 2 days to arrive so not a big deal. its just annoying to sort one problem and make another.
    good luck anyway mate.
    jamie
  17. ruffrida
    1,930
    313
    Nice 1 fella, sounds even more fun of a job todo now, will let ya know
  18. ruffrida
    1,930
    313
    Right!!
    New Thermostat on, found rad was leaking so that has been replaced to.
    Temp gauge went upto about 70c and then back down below 60c, that was about it.
    Drove to work this morning, over 40 miles in 18c - 19c, sat in traffic for half hour, temp gauge still didnt move!!
  19. aragorn
    18,605
    871
    check the reading on climate control or with vagcom
  20. ruffrida
    1,930
    313
    • Possible Causes
      • 17664 - Engine Coolant Temperature Circuit (G62): Open / Short to B+
        Possible Symptoms
      • Difficulties with starting a cold engine.
        • Diesel: an indication is extreme long time burning time of the glow indication light.
      • Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
      • RPM at idle is irregular.
      • With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
      • With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
      • Bad acceleration during warming up.
    • Wiring and/or connections faulty
    • Engine Coolant Temperature Sensor (G62) faulty
    Ordered a new one, should be ere Tuesday!!
  21. ruffrida
    1,930
    313
    Coolant sensor fitted last night.
    Temp gauge back to normal.
    Thanks to all for your input / help,
    Really cant fault ASN members, cheers ya'll
  22. coatesy
    1,920
    280
    that's because we are all just pure sexy beasts...
    glad you got the car back to how it should be.
  23. ruffrida
    1,930
    313
    I wish it was back to normal fella, still got limp mode fella, see my other thread.
    Pure Sexy beasts - I bet everyone would love to hear that at AITP, lol
