no reverse lights
vw754 Mar 20, 2014
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    I have no reverse (backup) lights on my b8 tdi.........ive today replaced the switch on the gearbox(genuine part) and still nothing,however when i use vcds and do a 'output test' they work..........:wtf:
  2. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,410
    648
    Check the fuse?
  3. vw754
    2,329
    58
    Apparantley the b8 does not have a fuse for the reverse lights,the switch i think sends the signal to the control module and it sends it to the reverse lights,unless some coding or something is not right,if it was the wires,then i t would not light up the bulbs when doing a output test,doin my head in :keule:
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,424
    2,374
    Is your car a manual ?. Looking at the wiring diagram for mine which is a B8 manual the switch on the gearbox connects to the onboard supply control unit directly.
    This will then communicate the gear information to the modules that need it over the CAN network. That would include the convenience module which is the one that seems to control the lights at the back.
    sounds to me like it may be some kind of error in coding. Has anything been changed on the car recently.
    I would look at the onboard supply control unit and see if any faults are flagged.
    There may be a measuring block that will show the gear the car is on, If this shows reverse as being detected then it's down to a coding error I would say.
    Karl.
  5. vw754
    2,329
    58
    yes 6 speed manual,all ive done is footwell lighting,and vent dial lighting,[​IMG]
    Tuesday,18,March,2014,15:59:44:07342
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ8K4************* License Plate: *******
    Mileage: 93960km-58384mi Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8K4******** Mileage: 93960km/58384miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 JM HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 3173
    Revision: 11H01---
    Coding: 0104002C18072118
    Shop #: WSC 00857 210 53146
    ASAM Dataset: EV_ECM20TDI03L906022JM A01005
    ROD: EV_ECM20TDI03L906022B.rod
    VCID: 79F2F89FF8C5FCD6DC9-802C
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
    Component: ESP8 front H04 0060
    Revision: -------- Serial number: --------------
    Coding: 160500
    Shop #: WSC 06325 000 00000
    VCID: 78F4FD9BCBCFE5DEA37-802D
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
    Component: BCM2 1.1 H70 0134
    Revision: 00002001
    Coding: 031100
    VCID: 306405BB633FFD9E2B7-8065
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H35 0039
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
    Component: KLIMA 3 ZONEN H06 0140
    Revision: D1000000 Serial number: 0106.07.081290
    Coding: 34040000
    VCID: 438E5A77C2897606C65-8016
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H22 0253
    Revision: 05022001 Serial number: 00000000076536
    Coding: 260050914034AF000001000300001D0D431D03080001014100 0000
    Shop #: WSC 06325 123 12345
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 110708 H05 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0038JD17KF99
    Coding: 30363434363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 3C7C218BB77709FE87F-8069
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME3D71407EM
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME3D546643I
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME6C580A0BT
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME7E7A443D/
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME7674367D9
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME76742D196
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H13 0013
    Revision: -------- Serial number: 90315HGE000K4
    Coding: 000016
    VCID: 3D7A2C8FA46D00F6B01-8068
    Component: E221 - MFL H02 0003
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 93928 km
    Time Indication: 0
    Date: 2014.03.18
    Time: 06:02:31
    Freeze Frame:
    (no units): 44.0
    Text: 2CFFFFFF84FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFF C0FFFFFFFF
    T.B. Angle: 32512.5°
    Raw, Index/Key Err.: 255 255 000
    Text: 1AFFFFFF9C0D021120030802
    Distance: 3330 cm
    (no units): 23.6
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
    Component: KOMBIINSTR. H16 0221
    Revision: 00200000 Serial number: 99551GM78
    Coding: 2F15080002002600010000
    VCID: 316200BF6835F496249-8064
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0091
    Revision: GB102039 Serial number: 3900G087118867
    Coding: 000303
    VCID: 46884363F1BB432EE1B-8013
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
    Component: TSG FA H10 0170
    Revision: Serial number: 0000007472436
    Coding: 011002204001410001
    VCID: 4084557BD39F6D1EDB7-8015
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0112712762
    Coding: 011F062200390440002001
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 AB HW: 8T0 035 223
    Component: DSP STD H07 0220
    Revision: S1900000
    Coding: 0203010102
    VCID: 6ED8DBC3B98BAB6E79B-803B
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
    Component: TSG BF H10 0170
    Revision: Serial number: 0000007454586
    VCID: 3F865687AE6112E6A2D-806A
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
    Component: EPB Audi B8 H05 0060
    Revision: 00000003 Serial number: 10000000063856
    Shop #: WSC 00000 000 00000
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 06324 000 00000
    VCID: 346C09AB5727C1BE4FF-8061
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 C HW: 8T2 035 186 C
    Component: Concert3 H02 0210
    Revision: 00000004 Serial number: AUZ5Z6H1095087
    Coding: 0502008201018D008359070000
    VCID: 38743D9B8B4F25DE637-806D
    Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
    Component: TSG HL H06 0170
    Revision: Serial number: 0000100152785
    Coding: 010002204001210001
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
    Component: TSG HR H06 0170
    Revision: Serial number: 0000100153550
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
    Component: FSE_256x BT H37 0600
    Revision: 00000000 Serial number: 00000005080232
    Coding: 0010320
    Shop #: WSC 00751 210 98641
    VCID: 3B7E22977A790EC68E5-806E
    End ---------------------------------------------------------------------
  6. vw754
    2,329
    58
    i had car for 7 months,only noticed they werent working a few days ago.
  7. vw754
    2,329
    58
    i need to see if coding is ok here in 'can' or if someone can do a scan of there car see if its same??? non satnav model
    or something else?
    i have vcds so any help is appreciated.
    Coding: 000303
    or here cent conv
  8. Liquidfusion-S3
    1,410
    648
    Would glad to help but don't have vcds and mine is sat nav
