No Radio + No Brake lights?!?
RIGZI Sep 7, 2010
  1. RIGZI
    RIGZI New Member
    27
    Hey Guys, i'm hoping someone has experienced the same thing... My head unit stopped working last night but the back light is still on (when ignition is of also) and i've just had a toot off a friendly road user to say my brake lights aren't working?? is it a coincidence that the 2 are linked...
    Does any have any solutions?
    Appreciated :)
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    fuses...
  3. 1animal1
    9,978
    well thats not very nice is it :
    hope you get it sorted, as Dave said, fuses, vagcom first ports of call
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    It's got to be fuses really hasn't it let's be honest. At the very least, it's the first place to look.
  5. RIGZI
    RIGZI New Member
    27
    Cheers for the replies
    First thing i checked when i pulled up at work were the fuses, i only had time to check the obvious ones which were all fine...
    look like i'm on the fog light switch on the way home haha
    Theres no fault codes come up on the liquid, next step vagcom...
    Don't suppose anybody can help in the Warrington Area?
    Check me... all take take take hahah
    I'll make it worth your while if anyone can help ;)
  6. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,368
    909
    Have you done anything electrical on the car, stereo, mods, lighting anything that would cause a short, any water leaking in or anything??
    As for making it worthwhile, i hope you aint offering a friendly 'toot' :sex:
  7. RIGZI
    RIGZI New Member
    27
    Ha, no friendly toots offered!
    Nope, no electrical mods.
  8. Sandip
    2,456
    99
    Pm'd
  9. RIGZI
    RIGZI New Member
    27
    After a bit of diagnostics expertise from Sandip, a hard reset (disconnect battery) which sorted the head unit, the conclusion of a knackered brake light seems to be the culprit... must of been co-incidence that tied the two together...
    So a big thankyou Sandip, for the little time we had to natter i learned a few tricks for the S3...
    cheers
  10. Sandip
    2,456
    99
    Anytime time bud, give us an update once you replace the brake light switch:)
  11. 1animal1
    9,978
    you dont need to change the brake light switch if its a post Y plate car....simple repair ;)
  12. Sandip
    2,456
    99
    It's only £8 for a new switch Tim lol
  13. 1animal1
    9,978
    haha ive never priced one cos the facelift one repairs so easily :)
    all you do is flip the lid thing off, take the spring out then get the pliers and twist the inner barrel around approx 5mm
  14. RIGZI
    RIGZI New Member
    27
    Nice one Tim, I'll gi that a go in the morning... tried sourcing a new switch from ECP to no avail!
  15. Sandip
    2,456
    99
    Yeah i had a look too lol They're out of stock:(
  16. J1 MBO
    J1 MBO Member
    52
    Hope you don't mind me latching on to this thread!
    I have jsut got my A3 back from the garage (for a fan motor replacement) only to realise that all of my brake lights weren't working!! This seems to have now turned into an intermittant problem now, but still a potentially dangerous situation!! I am not a pro yet when it comes to my A3 (new to the VAG) - does this sound like the same problem RIGZI? If so, where is the switch that needs replacing - if its a simple replacement I don't want to pay the garage lol!?!
    Thanks in advance.
  17. RIGZI
    RIGZI New Member
    27
    Follow this Instructions link and try resetting the switch... take off the cover under the steering column (6 torx bolts and a few clips hold it on) the switch is easy to get to...
    i bought this switch off ebay because mine was worn...
    ebay switch
  18. J1 MBO
    J1 MBO Member
    52
    Thanks for the rapid info!
    But sorry, forgot to mention that mine is a 1999 A3 1.6 Sport - are these instructions still valid? And, forgive me for proving myself as a complete Audi novice, but I couldn't see that the instructions tell you where the switch is in the first place?!!?
  19. RIGZI
    RIGZI New Member
    27
    the switch is on the brake pedal bracket... i don't if it'll be the same mate... do an ebay search that's how i found the correct one for mine.
