no power on stereo after double din conversion
scottie123 Apr 4, 2009
  1. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    :eyebrows:Right i completed my double din conversion last week, and i have been waiting for my quadlock converter lead to turn up.
    turn up yesterday, so i have plugged it in to the the new concert, but nothing is happening. No power to the stereo what so ever. checked the fuse onthe stereo, that seems ok.
    any body got any suggestions as i have spent nearly a week with no music in the car and i dont think i can handle it any longer!
  2. JohnS3
    JohnS3 Active Member
    3,032
    You'll also need +12v on the pin labelled DI-SENS. I think it's the next pin in the quadlock. That might sort it for you.
  3. JohnS3
    3,032
  4. scottie123
    1,972
    cheers for your reply john
    were is the best place to get the 12v from.
    can it be stolen from another pin on the connecter or does it come some where else?
  5. scottie123
    1,972
    bump 'cough'
    have the ideal oppurtunity to sort this out before the missus gets back from her stay in hospital.
    will make it easier that having to explain the ' i know i said it was just a simple job love and you would be able to use the stereo straight away but i have just got to.......'
    :jester:
  6. scottie123
    1,972
    cough splutter
  7. scottie123
    1,972
  8. scottie123
    1,972
    now the only problem is to source another quadlock pin so i can add another wire to the block.
    or perhaps there is a pin that is used that i can snaffle.
    lets look and see what i can find..
  9. JohnS3
    3,032
    Quadlock pin would be audi part number 000 979 225 for a 2.5 mm repair wire.
    For the 12v feed, just loop the repair wire to +UB (+12v) which is the next pin. That's how it's wired from the factory.
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    cant you borrow an un used connection (amp out?) wire in the short term? Cut n rewired.
  11. scottie123
    1,972
    excellent cheers for that john
    i think i may have now fund a spare unused pin on the quad lock than i can remove and reuse.
    Strange thing is, it is the tel mute pin that is unused on my loom to my iso connectors
  12. scottie123
    1,972
    dood you have read my mind lol!
    that were i have just been.
    out looking at the iso connectors and the quad lock comparing to see if a pin is un used.
    as yes there is one!
    :meeting:
  13. scottie123
    1,972
    now i am going to try and see how reuseable these use once pins are..........
    prepare for the swearing!!
  14. JohnS3
    3,032
    Fingers crossed then......
  15. scottie123
    1,972
    ok it is out and they can be reused with a bit of manipulation :)
    all soldered up so now going to see what happens.
    smoke or glory.......which will it be!!
  16. scottie123
    1,972
    well it works!!!!
    i have lights and everything!!
    no i have 2 problems left
    1stly with the diversity adapter. I have the adapter 2 plug to the stereo will has 2 leads. 1 for the standard arial connector.no problem there. 2nd connector is a small metal straight plug (cylindrical) with a small connection inside. And i have a female plug which looks like this should go into. But it just wont stay in. am i missing the point.
    Oh and 2nd problem. When i bought the stereo, i was told by the seller that the radio code was written on the bottom of the radio. It is. The only problem being that the code should be 4 digits long and the one one the bottom of the radio is 6 :think:
    how many attempts do you get before it is locked for good?:sex:
