no oil pressure 2.0 tdi
bigluke Jan 20, 2014
  1. bigluke
    bigluke New Member
    hi all wonder if anyone has a idea i have a 2.0 a6 tdi in the workshop right now with no oil pressure i've changed the pump even though the origenle looked brand new checked the pickup and still no oil pressure also checked the shaft into the oil pump and it's like new i have hooked up a oil pressure gauge and nothing what so ever and the head is dry also have blown up the oil lines in the bottom end wile the pump was off and air was reaching the head
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    there as been so many mods on the oil pump/assy on this car
    check the oil pump hexagonal drive
    check the shaft is 100mm long not 65mm
    check the hexagonal drive in the balance shaft
    if its had the short hex drive it will have rounded out the hex in the balance shaft and even the oil pump
    also check the chain drive if its a 140bhp engine
