No Long Coding Helper Option
chris1988brown Oct 18, 2012
  1. chris1988brown
    chris1988brown Member
    575
    I've recently bought my friends Vagcom cable. Having installed the software I am unable to get to some options that I want to (Gauge Sweep, Coming home lights, etc etc)
    The problem I am having is that all the guides tell me to go to 17-Instruments -> 07-Coding -> Long Coding Helper. The problem is in the coding section there is no option to select the long coding helper. I can access the long coding helper from the CAN Gateway module which is what is confusing me. Why is the long coding helper available in the CAN Gateway module but no others?
    chris
    Edit: Car is a 8P A3 2007 2.0 TDi S Line and the software is VAGCOM 11.11.3
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    125
    Have you used the long coding helper in the CAN gateway module?
    Is the software/cable original?
  3. chris1988brown
    575
    hi, yes ive used it in the CAN gateway module
    yes i believe they both are
  4. JST_A3
    JST_A3 Member
    99
    Chris,
    As far as I know the Instruments don't use long coding for the 8P. As you have seen the CAN gateway along with the Central Electronics and Central Convenience are the only modules that use long coding.
    Where did you pick up the coding instructions from, and are you sure they are for the 8P? The VCDS details are here:
    Audi A3 (8P) Instrument Cluster - Ross-Tech Wiki
    Steve
  5. Chewy Norman
    Chewy Norman New Member
    Does that mean you cant enable the gauge sweep on the 8P?
  6. chris1988brown
    575
    hi Steve i got the coding instructions from Google however now i come to think of it i don't recall it stating it was for the 8p, as chewy Norman says, does this mean it cant be done on the 8P?
    chris
  7. JST_A3
    JST_A3 Member
    99
    Chris,
    The gauge sweep is standard for the S3, but I think this is hard coded into the instrument cluster rather than it being a setting change, so you could do this but would need to replace the clocks.
    Coming home on the other hand is possible, details here:
    VW Golf/Jetta/Bora (1K/5M) Tweaks - Ross-Tech Wiki
    Steve
  8. NHN
    29,295
    1,701
    Post a log of your car.
