No lifter in ext valve???
aviel131 Apr 9, 2014
  1. aviel131
    aviel131 Member
    104
    Hello
    i opened my vc to change chain tensioner
    for my surprise I found this:
    Why there is is no lifter there?
  2. <tuffty/>
    20,896
    3,705
    Because its worn away... that (to coin a phrase) is fu*ked... new cam and new follower(s) required at the very least
  3. aviel131
    aviel131 Member
    104
    Should I replace intake cam too?
  4. aviel131
    aviel131 Member
    104
    And what about the valve is he ok?
  5. <tuffty/>
    20,896
    3,705
    If its not damaged then no need...
    Can't tell without stripping it but personally I would be looking to get a replacement head off another engine to be sure as there is no telling what other damage has happened...
  6. aviel131
    aviel131 Member
    104
    what damage can be happened?
  7. <tuffty/>
    20,896
    3,705
    follower bore could be damaged and would potentially cause this to happen again... valve could have damaged the valve guide... etc... This looks like an oil starvation issue so its difficult to tell exactly whats wrong from a picture...
    Basically you will need to strip the head and inspect it for damage and make a decision from there... 1.8t engines are fairly cheap to buy though while a full head rebuild can be expensive...
  8. <tuffty/>
    20,896
    3,705
  9. aviel131
    aviel131 Member
    104
    you mean bottom end rebuild too?
    maybe the compression problem came from the valves?
  10. <tuffty/>
    20,896
    3,705
    you had 50psi on all cylinders didn't you? it could be the valves but... like I said you will need to strip the engine to see...
    You could take the head off, rebuild it and see if the problem goes away... if it doesn't it means stripping the engine again to rebuild the bottom end too which is time and another headgasket/headbolts set too...
    Based on the issues you have had and the evidence you have presented I would be considering a full engine rebuild or trying to source another engine from somewhere... either way you will have to take the engine apart to confirm the problems...
    Its your choice at the end of the day... you could change the bits you think are the issue and get lucky or throw more and more money at it and end up with a worn engine that runs... or you could do it properly and rebuild or replace the engine..
    s3dave likes this.
