No hot water getting into the heating system? What can it be
DJM1982 Dec 6, 2010
  1. DJM1982
    DJM1982 Member
    394
    As above,
    Heating isn't working. The motors have been checked and there is one that needs replacing, but the real problems now seems to be that there is no hot water into the heating system.
    Has anyone got any ideas what this can be?? Help needed fast
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Possibly a gummed up heater matrix, or most likely an air lock in the coolant system....
  3. DJM1982
    DJM1982 Member
    394
    how do you cure the air lock then?
  4. unikarl
    unikarl Member
    367
    Bleed the system as you would your central heating at home. Run the car, let the engine get up to temperature and then open up the radiator valve to let free any air pockets.
  5. RallyX
    RallyX Flat Out VCDS Map User
    143
    Could also be a faulty thermostat.
  6. DJM1982
    DJM1982 Member
    394
    I think the garage has ordered a new thermostat. Looks likely to be a big bill though.
  7. AudiSport
    AudiSport Member
    496
    Thermostat. Or Head Gasket.
