NO heat at all ever
caddog Mar 17, 2008
  1. caddog
    caddog New Member
    The heaters in my 98 A4 have not worked since I bought the thing, a mechanic had a look and flushed the hoses but still nada, can anyone give me some fault finding advice or am I being to general with my problem, any help would be appreciated
    Stewart
  2. Siena
    Siena Active Member
    2,626
    Has it got climate control? Make sure the control flaps are working. I'd get it checked with VAG-COM or similar.
    If the temperature drops at sustained cruising speeds, then the thermostat is suspect, stuck open, and allowing the engine to over cool.
  3. caddog
    caddog New Member
    Thanks Siena will do
  4. AUDI TURBO
    AUDI TURBO Member
    577
    MY CLIMATE CONTROL has a mind of its own it goes up and down altering the fan speed?
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
    On pre-facelift sometimes one of the temp sensors (there are two in the cabin) can get clogged up. It's the little mesh of holes on the climate unit. Get an old tooth brush and give it a good clean.
  6. AUDI TURBO
    AUDI TURBO Member
    577
    ahhhhhhhhhhh i see i dint know taht it also seems to be blowing warm all the time even at 18 c i will try that
  7. joost
    joost Active Member
    1,169
    Mine's doing the same - like Siena said, it's most likely the temp control flap sticking. Allegedly, it's a dash-out job to sort hence why I've not even attempted it yet.
    Mine changes from sauna to cryogenics chamber at the drop of a hat. I'm keeping warm at the mo so I'm not overly fussed. Knowing my luck it'll try to freeze my moobs off in the morning.
    The fan speed may be due to the fact that the climate unit won't blow through certain vents until the engine has started warming up. Once the engine temp starts increasing, the fan speed will increase too IIRC.
