No ESP button??
Yaz Dec 17, 2008
  1. Yaz
    Yaz Member
    225
    I've noticed my S3 hasn't got an ESP button above the headunit where i believe it should be, instead there is a blank 'button'.
    What does this mean? Does my car not have ESP then?
    Thanks in advance guys!
  2. domburg
    domburg Member
    89
    i dont think so mate, it was an optional extra on the early cars and fitted as standard later on, if theres no esp button then i doubt you have it, my S3 doesnt and to be honest i cant see why it would need it
    dom
  3. Yaz
    Yaz Member
    225
    mmm, interesting... so i take it the quattro system takes care of everything then? Or how does it work if the newer S3's have both quattro and ESP??
    Sorry if this is a stupid post:unsure:
  4. domburg
    domburg Member
    89
    yaz - ive no idea lol (sorry) my s3 has never really had bother with traction or getting the power down on most road conditions, if there is loss of traction its very minimal and in my opinoin doesnt warrant the need of electronic trickery, to be honest i have no idea haow it all works, im sure some will be along shortly, sorry i cant be of anymore help
    dom
  5. Yaz
    Yaz Member
    225
    That's ok Dom, thanks for your input anyway, maybe we'll both find out soon enough! I've not had my S3 very long and haven't yet put it through it paces, but i too can confirm that the traction/grip is very good regardless.
    Anyway, at least i'm not the only one without an ESP button!:)
  6. benr
    benr Member
    819
    When you turn on the ignition does a traction control light come on?
    Its like a round arrow with an exclamation mark in the middle iirc
  7. Yaz
    Yaz Member
    225
    Hi mate, i know of the symbol you mean, but mine doesn't show this when you turn on the ignition. One of the first things i thought of tbh when i was looking for the ESP button.
    How about yours Dom?
  8. benr
    benr Member
    819
    Sorry i wouldnt have thought you have it then.
    I always thought there were some models with ESP but no button. But if no light i would say it doesnt have it. If you call a dealer with your reg they will tell you if it left the factory without.
  9. Yaz
    Yaz Member
    225
    Thanks pal, i was just curious how the whole system works...
  10. domburg
    domburg Member
    89
    just been out to check, and there no symbol of that sort on mine
  11. dares_uk
    dares_uk Member
    169
    interesting thread, was thinking this myself the other day,
    dont think i have it either.
    on a similar note, how do you know when the quattro/4wd kicks in??
    i also agree about grip, always brilliant so far, :)
  12. Yaz
    Yaz Member
    225
    Cant be long now before someone knows the answer...
  13. Yaz
    Yaz Member
    225
    Thanks pal! and exactly my point, how do you know when your car is working over time 'cos you're driving like a tw@t?!
  14. benr
    benr Member
    819
    In response to how it works you can do a google but the way i understand it is:
    it uses acceleration sensors, throttle sensors, brake sensors and steering sensors to work out where you are going and where you want to go to decide if your skidding. It will then brake each of the wheels independently to bring the car into line with where you want to go.
    http://www.metacafe.com/watch/731344/exotic_cars_info20_com_esp_electronic_stability_program/
    Hope this helps
  15. Yaz
    Yaz Member
    225
    Thanks Benr, that is very useful. I understand how ESP works, but what i meant was how does it all come together on the S3 with quattro and with or without ESP? Does that make sense?
    Basically mine doesn't have an ESP button, so i cant turn it off or on, but do i have ESP anyway thats 'built-in' to the system and works in conjunction with the quattro? Or it is a case that my model S3 doesn't have ESP at all and solely relies on the quattro system, abs, etc to keep the car straight? And if this is the case, how does my S3 compare to other S3's with the ESP button?
    Thank again guys.
  16. jojo
    28,846
    3,508
    Early 1999 S3's had no ESP, then it became an optional extra late 1999-2000, and I think it was then the facelift models came out, then ESP was standard equipment.
  17. Yaz
    Yaz Member
    225
    Maybe that's the case, although mine's a 2000 'W' reg...
  18. Essflee
    Essflee Well-Known Member
    2,142
    66
    To be honest if i feel a little mad moment comming on i tend to turn mine off, although i believe it still doesn't entirely go off ! As a safety aid it was designed for i would say its brilliant, usually if i give it a little on a tight bend (roundabout) you can feel it violently kick in to stop under steer and pulling the nose back in, not very exciting but a very good safety idea.....
  19. benr
    benr Member
    819
    Yep totally agreed its pretty good as a safety function and gives a bit of piece of mind.
    It can be a pain in the backside on wet/quick/hill starts as it seems to make it very jerky when the wheels spin up.
  20. Yaz
    Yaz Member
    225
    Well it dont look like my car has it, but it does feel very surefooted on the twisty stuff regardless. It still has the quattro at least:respekt:
  21. fingermouse
    fingermouse thats me
    3,991
    111
    I turn mine off to drive quicker other wise it just bogs you down, also a knightmare in the snow going up hill especially.
  22. benr
    benr Member
    819
    yep the manual recommends turning it off in conditions such as hills in snow.
  23. buckas
    buckas Member
    749
    ESP saved my bacon on numerous occasions!
  24. S3mad
    S3mad Dark Knight
    946
    You dont need it . Its a waste of time just slows you down its better not to have it i think
  25. 1animal1
    9,978
    yeah but when times come when its leathering it down and other conditions where you would normally need it......id much rather have it....TBH i leave mine on most of the time as its effort to turn it off....like the other chaps above though i turn it off when i know im gonna be ragging it.
    easy to say you dont need it when you havent got it - it really isnt a waste of time either....sorry to disagree mad
  26. Essflee
    2,142
    66
    I reckon Esp must prevent hundreds if not thousands of accidents a year, big and small.....i wouldn't say its a waste of time.
  27. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Mine stays on unless I need a quick getaway at a wet junction.
  28. bl_1969
    bl_1969 Roads? We Dont Need Roads!!!!
    358
    Hmmmm I have never turned it off since I got the car.
    So reading reading this thread.... it (ESP) kicks in sometimes and slows the car down... is that right?
  29. Essflee
    2,142
    66
    Yeah, i'd be suprised if you haven't experienced it yourself at some point, it doesn't feel very nice really....it can definately hamper a quick launch from stand still....best to just rely on the haldex for that !!
  30. bl_1969
    358
    I went from a 1LTR polo to this car so I even a hampered start is 10,000 times better than what I have known :yahoo:
    I will definitely give it a try tho, turn it off I mean.
  31. Shug1874
    Shug1874 Member
    80
    My esp works by cutting all power for at least 5 secs :shrug:
  32. benr
    benr Member
    819
    mine doesnt. 5 seconds is a very long time. are you sure? Mine slows it down but doesnt cut power. If anything it applies brakes.
  33. S3mad
    S3mad Dark Knight
    946
    Well i have had it on many cars and i didnt feel any safer !
    i like to have fun in the car . As whats the point of all the power when you cant have fun !!
    :p
  34. jojo
    28,846
    3,508
    Mine has no ESP, never had the need for it in 8 years or so of ownership, but then again, I never really push the car to it's limit on the public road, out on the track I have, but on the road, 8/10ths is probably my limit on an empty road.
  35. Yaz
    Yaz Member
    225
    So how did you find the grip/handling on the track without ESP Jojo?
