No epc light , non start
cctuning Mar 11, 2014
  1. cctuning
    cctuning New Member
    Hi, I've got an Audi S3 8l 2002 and intermitantly the epc light is not there and I get no communication to the ecu,also the fuel pump does not prime when this happens. There's no dtc's as the ecu losses it's com's.
    ive changed the main ecu relay and fuel pump relay but still the same.
    Im thinking maybe ECU but not 100% sure as when I go to test it then starts to work again so alls ok.
    Thanks in advance
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    How are you testing the ecu? In this situation to test ecu i would program a new one in and leave it there till the fault repeats. However if there is a short somewhere causing this you risk damaging the second ecu.
    Use measuring block 125 in various modules with vcds to try to establish the comms lost.
    I have no real experience with petrol so cant point out any common failure points on your engine.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would check earths under the battery, then make sure the ECU is not sitting in water (under the scuttle panel)
