No cruise control leads to no power steering
Audiohitch Oct 29, 2013
  1. Audiohitch
    Audiohitch Member
    Ok so only had my audi for 3 weeks. When I got the car the cruise control wasn't working so it was booked in with the dealer (not audi) to have sorted on Monday. They had it half the day and got it down to being the stalk has gone faulty. Gone back in today to have the the stalk replaced only to be left with a car with no cruise control and no power steering.
    So been told when they put the stalk in to pair up with the car, the stalk wouldn't pair up which then lead to the power steering to stop working.
    So they kept the car in and working on it tomorrow.
    Any ideas?
  2. Lewis583
    956
    91
    Sounds like they have either altered the coding within the Steering Control unit or they've not carried out the basic settings which tells the Steering ECU the steering lock stops reading.
    It is very easy to miss something on the coding and for it to disable the PAS, though I wouldn't have thought a simple column switch replacement would require the coding adjusted.
  3. hades-
    9,481
    646
    are they vag garage ?
  4. Audiohitch
    Audiohitch Member
    They took it to a local garage which apparently has some vagcom like equipment.
  5. hades-
    9,481
    646
    sorry i ment does he know what hes doin with our cars
    as above sounds like a codeing fault of he aint redone the steering angle sensor
  6. Audiohitch
    Audiohitch Member
    They've had the car all day and apparently taken to another specialist.
    Whatever they have done they have really must of screwed it up.
    So I am still stuck in Leeds at my in-laws (I live in hull)
    I have to cancel some appointments I had this week, but the worse thing is my daughter is going to miss the Halloween party.
  7. hades-
    9,481
    646
    and you didnt demand a hire car ?
  8. Audiohitch
    Audiohitch Member
    Just off the phone with the dealer. Car only half done. Something with the angle sensor. So another day with them having the car. Told my daughter she can't go to the Halloween party so now have to deal with a upset screaming 5 year old.
  9. Audiohitch
    Audiohitch Member
    Don't have courtesy cars with it being a small car dealership.
  10. jphc
    jphc RS6 Dreamin'
    163
    9
    I think the lesson here is ALWAYS take your car to a reputable dealer.
  11. sliced
    sliced Drive safe, stay alive.
    1,562
    334
    Has the battery been disconnected? That usually causes a power steering warning till u drive like 100m or so
  12. jphc
    jphc RS6 Dreamin'
    163
    9
    I thought that was ESP?
  13. Audiohitch
    Audiohitch Member
    I have no idea. I'm only relaying what I have been told. It's still with the dealer. I've not been in the car since Monday.
  14. sliced
    1,562
    334
  15. bmh.01
    bmh.01 Member
    291
    17
    If they were just changing the stalk then they don't need to touch the coding as they aren't retrofitting it, it's a 15 minute physical swap only. They've obviously managed to break something (probably steering angle related) and don't know how to fix it.
    You have to remove the steering module from under the wheel with the angle sensor to change the stalk so it's definetly something they've done.
  16. jphc
    jphc RS6 Dreamin'
    163
    9
  17. Audiohitch
    Audiohitch Member
    Just got the car back after 4 days.
    Work done consists of;
    Reset coding sand basis settings of traction sensors, steering sensors and column module.
    Reactivate cruise control.
    Just realised when pulling up at home the rear wiper arm is not working
    ...."insert many curse words here"....
  18. Audiohitch
    Audiohitch Member
    okay just plugged brother-in-laws dumb vagcom in and new errors have come up.
    Address 17: Instruments
    Controller:
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer
    Controller:
    No Faults Found
  19. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    they have a probably deactivated the rear wiper by mistake, just code again under steering module 16.
  20. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Im in hull in the morning, i can make it early if you need to, and scan with a proper vcds. Any good to you? if id seen this thread sooner i would have offered to help.
  21. Ash187
    7,495
    744
    Wow that's a 1 hour job to replace cruise stalk and code the power steering, 4 days is a joke!
