No cold air - no error codes
Kev-in-Spain Aug 12, 2017
  1. Kev-in-Spain
    Kev-in-Spain New Member
    Hi all,
    Sorry if this is a repeat post but I've had a look through this section of the forum and none of the other posts seem to fit my issue:
    Audi A3 1.9tdi 2003 Slimline:
    The aircon stopped working and the diagnosis was a failing/failed compressor. I had it replaced, together with the expansion valve and, obviously, re-gassed.
    The system still blows no cold air, although the air-con tubes do get cold, but the diagnostic scan returns no error codes.
    So my question is, what would be the next thing to check? Is there a common part failure on this model that I should look at?
    Thanks in advance
    Kev
  2. vag-tech
    vag-tech Site Sponsor Site Sponsor Team Ibis VCDS Map User Audi A3
    257
    82
    If your pipes are chilling you may have a temp blend flap issue. This can be actuated/tested with decent diagnostic interface.
