no clutch after bleeding it??
Slinequattro Dec 3, 2011
  1. Slinequattro
    Slinequattro New Member
    13
    Afternoon gents...
    I have a 05 2.0tdi quattro with no clutch now for some reason...?
    i wanted to bleed the brakes and clutch today.. they were ok but a thought they could be better so i started with the clutch so put a hose over nipple and done down...open...close up... there was alot of air coming out so kept on going but now there is no pedal at all, it just flops to the floor...
    is there anything i've done wrong or can do?
    cheers
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    You have to keep pumping the pedal, it takes about 50 pumps to get back, took me ages when i did the R32 one.
  3. Adam.
    Adam. Meow.
    662
    34
    Get yourself a gunson easy bleed kit.
  4. fangio
    fangio Well-Known Member
    1,497
    179
    Top the fluid up?:sorry:
  5. a3glenn
    a3glenn 6th gear
    99
    did mine on saturday, you cant do it by pumping the pedal.
    you have to get a bleeding kit that go's on top of the resvoir to push the fluid though the clutch pipes, takes 20 sec this way (tells you this way in the haynes manuel)
    hope this helps
  6. vorney
    vorney Member
    123
    only way to bleed is a pressure bleeder all vags seem to be same
  7. Adam.
    Adam. Meow.
    662
    34
    Pressure bleeders are still a bit iffy.
    I use a vacuum bleeder attached to a compressor. :D
  8. vorney
    vorney Member
    123
    we never had a problem yet but there is always time :arco:
    AdriansS3 likes this.
