No brake lights!
chuffer Oct 10, 2005
  1. chuffer
    chuffer Member
    72
    I've got no brake lights, what could it be? (98 A3 1.8T)
    I've changed the bulbs.
  2. 28v6
    28v6 Guest
    Bad Earth? Fault in the Brake switch at the foot pedal.... /ubbthreads/images/graemlins/froggie_red.gif
  3. PaulRS3
    PaulRS3 Well-Known Member
    1,226
    153
    fuse blown or any mentioned above could cause it.
  4. s3tle
    s3tle Member
    239
    yep i agree, i would think its likely to be the brake switch at the foot pedal, easy to replace yourself
  5. benk
    benk Member
    469
  6. chuffer
    chuffer Member
    72
    Yeap, the brake pedal switch
  7. Guys, could this be the same problem with mine, except it's the reverse lights that won't work?
  8. rojocho
    rojocho Member
    50
    reverse switch may be at fault, try shorting wire's out at switch to see if lamps come on.
    used a fused wire if you can to avoid grounding it, inline 5amp would be more than enough
