No brake lights (Switch issue)
A3_Turbo Oct 22, 2007
  1. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    Hi guys ive got no brake lights still havnt had for a while i dont think! Ive done the fuse and its not the bulbs so its not that.
    Some-one said about the switch under the brake pedal must be that, is it easy to fix?
  2. rodenal
    rodenal Active Member
    1,992
    Yeah fairly simple but fiddly give it an hour or so to do
  3. marms
    marms Member
    833
    It's one of those jobs that is easy when you've done it once.
    Basically look up under the dash above the brake pedal.
    The switch in question is easy to spot.
    You need to turn this switch a quarter turn and it will pop out.
    Swap the cable to the new switch and refit.
    When you have done this once it is a simple 2 minute job. The first time I did one it took me 45 mins with lots of swearing and shouting.
  4. jeffers999
    jeffers999 got boost
    390
    yea i changed mine last week simple enough these seem common to go these days ...
  5. Jimmeh
    Jimmeh Active Member
    1,438
    I seem to be having the same problem.
    this morning my lights were fine, but after a spirited drive this afternoon I seem to have lost all three brake lights..
    can someone point me in the right direction for a new switch? do you have to take the whole dashboard off to gain access?! :(
  6. marms
    marms Member
    833
    You just need to remove the lower panel under the steering wheel. then get your head in the footwell and have a look at the top of the brake pedal. It's very obvious when you get in there. Get a new switch from your local GSF Car parts, they're as cheap as chips.
  7. 1animal1
    9,978
    Tip- dont buy a cheap switch i.e from Euro parts!!! they last about 5000miles...i went through 3 from Euro parts on my old car only to end up going direct to Audi.... the quality of the metal contacts is shocking and arks like nobodies business......
