  1. cammage08
    cammage08 Member
    171
    10
    Hi, i know theres loads of posts about boost loss but wanted to add my own. I have a stage 1 mapped S3, was out in the car this morning accelerating from 40-60 when suddenly lost boost...? No eml or other symptoms... Still drives ok but about 60% of full potential. Recently did n249 bypass which is still connected and fine. Scanned with VCDS nothing major other than 17861 EGT sensor. Would this cause the sudden loss of power im experiencing? Any help would be appreciated.
    Chris
  2. <tuffty/>
    21,898
    4,206
    EGT probe unplugged? with this unplugged the ECU will go into permanent protection and over fuell... this won't be helping performance at all... check that its connected... the EGT probe black box is under the inlet manifold and can be seen by removing the plastic trim in front of the inlet mani...
    If this is plugged in then it could be wiring,,,
  3. ceS3r
    ceS3r Member
    97
    9
    Hi, did you ever sort this problem? Sorry for hijacking your thread but I've had this code for a while now. Funny thing is that, while logging the other day I could see that my egt was reading temps perfectly, then after 20 mins of driving readings jumped straight to 1100 °C and stayed there. Does this means that the EGT is broken and I need a new one? Or is there any fix to this issue? I've heard that you can also map it out
  4. <tuffty/>
    21,898
    4,206
    New EGT probe required
    <tuffty>
