Hi all sometimes when I first start my car it has no boost in first gear then when you hit second it seems fine and after you get going it doesnt reappear until the next day or so its a 1.9tdi 130. Could this be sticky turbo vanes ?
Ok will do thanks for the reply are the vac pipes on the drivera side as I have been getting a loud hissing noise which continues a bit after the car is turned off from under the bonnet on the drivers side up near the airbox.
Is this not a safety feature to help look after the turbo when the engine is cold?
On my Ibiza Cupra, the engine prevented boost for about a minute after start-up.
The hissing sound from the drivers area may be your air-conditioning - mine does the same.
