No bonnet open warning?!Wiring diagram please for clocks/locks
@udi A3
Well-Known Member
Hull, UK
Website
www.immotec.co.uk
As above, I know danio supplied me some but i cant for the life of me find them!
I am finally getting around to fitting my bigger washer bottle and low warning, but tonight the alarm was playing silly buggers.
The bonnet up warning on the dash has never worked as far as i know, but the dash was from another car so i think maybe the wires are a little different, I had to use VCDS to find the fault that the car should be capable of displaying i think!
Clocks are from a 2002 tdi quattro. Door open warning works fine.
Is there anything else that manages these warnings?
I just assumed it was, and if it does then this would have saved me pulling the vcds out !
Yeah there's no bonnet open warning. If the bonnet is opened whilst car is alarmed it will trigger it though.
It was bizaar, it must have opened in the cold after a long run this afternoon. Then the alarm went off, and it wouldnt re arm, only ever did this before when i had an iffy door switch. Ive just unplugged the bonnet switch for now.
its a shame there is no warning on the dash that the bonnets open, that would be nice. aparently the switch it supposed to stop the wipers from working when the bonnets open
Hi after a long break.There is a bonnet warning lamp on dis and it can be connected however now it is not wired up to the clocks. It must be something different that trigger your alarm.Still need those diagrams???
Sure danio, would be awesome, how much extra work to wire the DIS warning in? is there a contact already on the loom or is this needing a new wire from the bonnet switch? Do you know the pin number on the cluster?
Im also thinking about wiring in the lamp failure warnings too, any info on those or could i just make up a simple controller and output to the clocks?
It was defo the bonnet switch caused the alarm, vcds told me so :p
Right pin for the bonnet on the cluster is 25 on the green socket.
Sensor from the bonnet lock already should be wired to the scuttle panel but I don't remember which pin is that, however will let you know on Saturday.
To fit warning light system I have to say it is not an easy job. First just have a look under a steering wheel where all relays are for relay number 381 or just make me a photo. You might have it all system already on the car.
