No access to controler 17 instruments
simon- May 7, 2012
  1. simon-
    simon- New Member
    13
    Hi I have just finished a retro fit of an RNS e into my A4 B7 2.0td, when I came to code the HU in I find I cannot access controler 17 for instruments to get directions on to the DIS, can anyone shed any light on what I may be doing wrong. I have cleared all the faults from the inital install and ran the car for a couple of miles to test the sat nav which all seems to be working as it should, but thefault oncontrol 17 comes back. I am no expert with VCDS as I have only just bought it from Nigel. Below is my print out.
    Thanks for any help Simon.
    Monday,07,May,2012,14:12:43:22317
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E68A080506 Mileage: 225300km/139994miles
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Part No SW: 03G 906 016 JD HW: 03G 906 016 JD
    Component: R4 2,0L EDC G000SG 9643
    Revision: --H05--- Serial number: XXXXXXXXXXXXXX
    Coding: 0000072
    Shop #: WSC 06335 000 00000
    VCID: 6ED8B547798C249
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    VCID: 2C5C7F4F8F10169
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CDCBF4F1C90D69
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 10001
    Shop #: WSC 06335
    VCID: 3D7A420B376A8F1
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H14 4230
    Revision: 91H14423 Serial number: 0036M0GA6YMX
    Coding: 0031612
    VCID: 3B7E4C137A7E811
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 00042
    Shop #: WSC 06335
    VCID: 41823EFB4B92EB1
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 L HW: 8E0 920 951 L
    Component: KOMBI+WFS 4 H14 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0006418
    Shop #: WSC 00236 210 89910
    VCID: 336E6433512E491
    1 Fault Found:
    01305 - Databus for Infotainment
    014 - Defective - Intermittent
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
    Component: RNS-E HIGH EU H72 0650
    Revision: 01S Serial number: AUZBZ7F1152631
    Coding: 0413113
    Shop #: WSC 06325 000 00000
    VCID: 2C5C7F4F8C10169
    6 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 87
    Time Indication: 0
    Date: 2012.04.19
    Time: 16:26:41
    Freeze Frame:
    Mileage: 655350 km
    Count: 505
    Clock: 10:00
    00856 - Radio Antenna
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 68
    Time Indication: 0
    Date: 2010.06.16
    Time: 15:47:35
    Freeze Frame:
    Mileage: 655350 km
    Count: 2004
    Clock: 16:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 13
    Reset counter: 90
    Time Indication: 0
    Date: 2012.02.25
    Time: 10:12:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Reset counter: 50
    Time Indication: 0
    Date: 2009.09.18
    Time: 14:41:13
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 90
    Time Indication: 0
    Date: 2012.04.05
    Time: 16:41:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Time Indication: 0
    Date: 2012.04.19
    Time: 16:24:53
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDE3C53999E511
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CQ
    Component: Komfortgerát T3B 4336
    Coding: 07151
    Shop #: WSC 06335
    VCID: 820071F78E14B09
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0413113
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 87
    Time Indication: 0
    Date: 2012.04.19
    Time: 16:26:41
    Freeze Frame:
    Mileage: 655350 km
    Count: 505
    Clock: 10:00
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 68
    Time Indication: 0
    Date: 2010.06.16
    Time: 15:47:35
    Freeze Frame:
    Mileage: 655350 km
    Count: 2004
    Clock: 16:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 13
    Reset counter: 90
    Time Indication: 0
    Date: 2012.02.25
    Time: 10:12:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 50
    Time Indication: 0
    Date: 2009.09.18
    Time: 14:41:13
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 90
    Time Indication: 0
    Date: 2012.04.05
    Time: 16:41:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 705
    Clock: 13:57
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Time Indication: 0
    Date: 2012.04.19
    Time: 16:24:53
    End ---------------------------------------------------------------------
  2. simon-
    simon- New Member
    13
    After a lot of reading on the Ross-Tech web site I have managed to get access to controler 17. Although I cleared all the faults initally when I have driven the car it has put all the faults back on so it seem's denying me access to 17. After rescanning the car making a log file and clearing all the DTC's I rescanned the car and only a few faults were still on the list and I was able to access control 17.
    I'm now going to spend the rest of the day with the coffee pot and the Ross-Tech manual.
  3. NHN
    29,298
    1,701
    1st clear all the errors & then rescan.
    Unless you have a colour cluster, then you dont get dis directions without turning of the rns momentarily & back on, its a bug with red dis clusters, hence why all factory fit rns units were fitted with colour clusters.
  4. simon-
    simon- New Member
    13
    Hi Nigel, yeah I got it read more type less (smacked hand).lol
    I have just been reading about the red DIS bug, am I right in thinking though that once the sat nav is comunicating with DIS it will continue to do so untill the ignition is switched off. If so I can live with that as I only realy use it on my monthly trip to Cardiff
  5. NHN
    29,298
    1,701
    Yes once you have it running, it should continue to work until you stop it.
  6. Pj4388dunne
    Pj4388dunne New Member
    Hi
    im new new audi's but after ready this im hoping you can help?
    I have a 2004 audi a3 ive had my friend over today with his vag com, now most of the modules worked fine but when I try to go into 17-instruments and go into coding there is no long code helper on the next screen do adjust any of the mods? most of the other modules I tried had the long code helper so I can adjust the mods but not instruments?
    hope you or someone can help?
    cheers
    jay
