Nitrogen in tyres
jdp1962 Feb 28, 2010
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,598
    3,172
    I've just been browsing a tyre website for a quote, and it told me that for an extra £1 per tyre, I could choose to have them filled with nitrogen.
    Has anyone heard of this before? What are the benefits of it?
  2. adamss24
    adamss24 Well-Known Member
    4,584
    408
    Its supposed to be an inert gas wich does not expand too much from when the tyres get hot and they will also save mpg. Its also denser than air wich means it wont excape that easy ... I would say its just marketing rubbish...gasses will behave symilar in the same given condition.
  3. jdp1962
    8,598
    3,172
    I suspect you're right, given that air is already 78% nitrogen anyway.
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    True about the 78% of nitrogen, but you need to think that around 20% is oxygen and how much that expands.
    I know from a track day, my tyre pressure on about 8 laps were increasing from 34 to 46 on air.
  5. Nutkin
    Nutkin Member
    830
    nitrogen is better go for it
  6. Nutkin
    Nutkin Member
    830
    how on earth do you word that one out?
  7. aragorn
    18,657
    875
    And what happens when you need to top them off...
  8. Nutkin
    Nutkin Member
    830
    still gonna be higher percentage of nitrogen. but yeah its a valid point.
  9. paul20v
    paul20v Audi fanatic
    1,114
    Hi
    Filling Tyres with Nitrogen
    Beneficial in specialist applications
    The air we breath (and the normal compressed air used to inflate tyres) contains 78% Nitrogen, 21% Oxygen and 1% other gases.
    Purified nitrogen has been used to inflate tyres on aircraft and racing cars for many years, but now some tyre specialists are offering nitrogen inflation for ordinary car and van tyres.
    The advantages of using nitrogen in specialist applications are clear
    Planes fly at heights where temperatures may be as low as -40C. Any moisture in the tyres can freeze causing vibration and balance problems when landing. Pure nitrogen is dry so eliminates this problem (as would using dried compressed air)
    In motor sport the smallest fraction of a second can make the difference between winning and losing. Filling with nitrogen can reduce tyre pressure variation caused by changes in tyre temperature.
    For passenger car applications the main claims seem to be
    Reduced corrosion – because unlike air there's no moisture in pure nitrogen
    Slower rate of pressure loss – because nitrogen molecules are larger than oxygen molecules (which make up 21% of compressed air)
    Leakage can occur through the tyre's inner liner but can also occur through the valve, punctures, or failure of the seal between tyre and wheel rim. Pure nitrogen might leak more slowly through the liner, but regular checks of tyre condition and pressures will still be essential.
    Corrosion of the tyre through use of normal compressed air alone is most unlikely because only the outer tread band of a car tyre contains steel – the amount of moisture reaching it from the inside is minimal.
    Changing to nitrogen involves removing all the air which is already in the tyres and then re-inflating them with purified compressed nitrogen. There will be a one-off charge per tyre but once filled with nitrogen any future top-ups would also have to be with nitrogen if any advantages are to be maintained.
    Overall, while accepting the possibility of purified nitrogen being of benefit in certain applications, we don't think that the cost and possible inconvenience are justified for normal passenger car use.
  10. AudiLeon
    2,250
    192
    Less chance of leak though, so less reason for them to need pumping up.
  11. quattrojames
    14,068
    585
    If you got a puncture wouldn't you suffocate?
    And what if they explode?
    :sadlike:
  12. Nutkin
    Nutkin Member
    830
    No
    and they wont, less chance of these to explode as no moisture in the tyre = less chance of a blowout.
  13. AudiLeon
    2,250
    192
    If they did go pop, it'd just be the same as air.
  14. adamss24
    4,584
    408
    Eh ? Do you wanna get technical or you wanna pardon me english ? Not using any spell check as any other people + english isn't me mother's language !
  15. quattrojames
    14,068
    585
    My humour is lost in here ..... :undwech:
    :Flush:
  16. AudiLeon
    2,250
    192
    LOL, straight over my head!
  17. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    ok then, so what major national dealership will offer you such a service should you wish to have your tyres filled with Nitrogen?
  18. Nutkin
    Nutkin Member
    830
    Technical, if you'd rather take it to German im fairly fluent :)
    All gases react different. The oxygen in air has a habit of forming water droplets under extreme preasure for one. Nitrogen is fairly non reactive hense why they use it in crisp packets. It is also why as above they use it to fill the tyres for race cars etc. Again for average joe public maybe not relavent. But if you like to take her on a track day every now and then i get my track wheels filled wth N2
    If you really want to get technical i can explain how the tripple bond make up of the nitrogen gas is incredibly strong, and causes said effects.
    Costco?
  19. howdy quattro
    howdy quattro Member
    320
    Its ok James, I'm with you on this one, when I first saw this I thought 'what if a nail goes through and catches a radial cord?!? Ka-boooooooooom', but it appears the scientists among us have squashed all of our concerns!!
  20. jdp1962
    8,598
    3,172
    I think I've decided to stick with normal air. It's served me well this past 47 years.
  21. AudiLeon
    2,250
    192
    Now I just can't tell if you're joking, nitrogen isn't flamable?
  22. howdy quattro
    320
    Apparently its not combustible, which is a huge shame, I'd love to see some insurance claims using that as a reason!!!
  23. AudiLeon
    2,250
    192
    I'm glad its not! Most fire suppresion systems in the world are charged with nitrogen :| lol
  24. BahnStormer77
    BahnStormer77 BahnStormer
    2,778
    60
    Nitrogen for car tyres = inert and dry, so less chance of pressure change as tyre temp changes.... and less chance of corrosion.... but tbh you're 80% of the way there with clean dry air, so get it done a the garage in the first place and then top up with a decent air compressor (i.e. avoid the footpump).
    I'm sure I've had the nitrogen option for free most of the time...
