Nightmare of a day
coreythorny May 6, 2013
  1. coreythorny
    coreythorny Active Member
    463
    74
    Finally fitted my H&R springs.
    Then found I had a bulb out, drivers sidelight infact. I have LEDs from Trups, so pulled it out and the light itself fell into the headlight as I pulled it out.
    Managed to fish it out with some wire and sticky tape through the DRL light (pre-facelift Bi-xenons)
    Tested and worked fine.
    Put it all back together, headlights on. Now the other sidelight and Xenon didn't work.
    Turns out my battery had died as it would turn over.
    Jump started and all worked fine.
    However; now the Drivers sidelight, the one which fell in the light isn't working again. I presume it's working loose in the holder. Has anyone else had this problem?
    Also, I noticed on idle I get a little "blip" every now and again. No ticking at high rpm though.
    Smelt my oil and it smelt of petrol :( sounds like cam follower.
    What's the worse this can cause and what extent can it get to?
    My cars a 2008 S3 8P Pre-facelift.
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    606
    Hi mate ,id change the cam follower asap,any reciepts in audi folder to see when it was lasted changed?
  3. coreythorny
    463
    74
    I'll have a look when I get home.
    I do have a years Audi Approved warranty but will they refuse the work due to the lowering springs now? No chance ill take them off any time soon lol.
  4. Kelza
    3,078
    606
    Id get them to check cam follower ,lights and battery ..
  5. coreythorny
    463
    74
    will the spring only void relatable parts? Suspension, wheels etc
  6. bmh.01
    bmh.01 Member
    291
    17
    If you've fitted springs then you should be capable of checking the cam follower yourself, its a ten minute job. I bet its fine and you've just got a bit of car hypocondria because of the other problems you've had.
  7. coreythorny
    463
    74
    Quite possibly, is oil smelling of petrol normal regardless then? I wouldn't say it was nose stripping strong.
    There's no fuel smell outside?
  8. coreythorny
    463
    74
    Here's the car lowered also :D
