Nightmare caliper hangers
B5 BIKER Nov 3, 2012
  1. B5 BIKER
    B5 BIKER Member
    266
    Have been trying to change my rear calipers and discs today
    Calipers are off but whatever donkey had them off before me has rung
    all the inside of the 8mm Allen bolts for the hangers.
    I have used wd40, vice-grip, and even heat but there is no shifting them.
    Has anyone got any suggestions before I get the grinder out in the morning?
  2. aragorn
    18,663
    878
    either grinder, or weld a bolt onto the head.
  3. B5 BIKER
    B5 BIKER Member
    266
    Grinder it needed, but got it done. Thank god.
    All done now, all I have to do is sort the spongy pedal.
    Bled all the calipers loads, and thought I got all the air out.
    anyone got any advice, as this was my first time to bleed them so it's all new
  4. aragorn
    18,663
    878
    Mine have the same issue. Try driving it a bit and bleeding again, air gets stuck in the workings of the caliper.
  5. B5 BIKER
    B5 BIKER Member
    266
    Will do, have a 100 mile round trip tomorrow and can check when I get home if it's not too dark.
    cheers kev
  6. jcb
    jcb Active Member
    4,132
    13
    i use a pressure bleeder now
    makes it a doddle
  7. aragorn
    18,663
    878
    So do i, and after 3 weeks of ****ing around i still have a spongey pedal!
    I believe air gets trapped in the handbrake mechanism and finds it difficult to find its way out.
  8. B5 BIKER
    B5 BIKER Member
    266
    Finally got around to bleeding the brakes again today.
    I think you were right about the rear calipers Aragorn.
    Even though I had bled them quiet a bit, they were full of air again today.
    Nice and firm now and biting like a cranky wife.
    For reference for anyone needing new brakes, I got full kit of discs and pads with rear bearings pre pressed and new abs rings fitted for 189 euros from CAR-BOCK: Ersatzteile Audi Seat Skoda VW
    good value on the prices of parts (compared to Irish suppliers anyway)
    Quality is faultless
