nhn in box full
a8 tech back Jul 24, 2011
  1. a8 tech back
    a8 tech back Member
    198
    hi mate your inbox is full so here is the info you need
    [FONT=verdana, helvetica, sans-serif]Signal Tyre pressure gauge[/FONT]
    [FONT=verdana, helvetica, sans-serif]TPM [/FONT]
    [FONT=verdana, helvetica, sans-serif]The tyre pressure monitor is a software module in the ESP/ABS control unit to detect slow tyre pressure losses on individual wheels. The system detects pressure losses of more than approximately 30% of the starting pressure. [/FONT]
    [FONT=verdana, helvetica, sans-serif]A recalibration is required after every pressure change, after every tyre change (including swapping from front to rear) and after any work has been performed on the running gear. [/FONT]
    [FONT=verdana, helvetica, sans-serif]1. Basic setting/restore delivery condition [/FONT]
    [FONT=verdana, helvetica, sans-serif]After every system reset the tyre pressure monitor must be started up for at least 2 seconds by simultaneously pressing the tyre pressure monitor and TCS/ESP buttons. After an initial calibration no further calibration is necessary. [/FONT]
    [FONT=verdana, helvetica, sans-serif]2. Calibration (save tyre pressures) [/FONT]
    [FONT=verdana, helvetica, sans-serif]Press and hold the TPM button at ignition on for > 2 seconds[/FONT]
    [FONT=verdana, helvetica, sans-serif]TPM lamp remains lit as long as the button is held down. A successful calibration is acknowledged by an acoustic tone. A successful calibration can be checked indirectly by way of measured value block 17 by comparing the kilometre reading in measured value block 17 with the current kilometre reading on the speedometer (to an accuracy of 10 KM). [/FONT]
    [FONT=verdana, helvetica, sans-serif]3. Diagnostic aids [/FONT]
    [FONT=verdana, helvetica, sans-serif]MVB 16 kilometre reading and last pressure warning[/FONT]
    [FONT=verdana, helvetica, sans-serif]MVB 17 Kilometre reading at last initialisation[/FONT]
    [FONT=verdana, helvetica, sans-serif]MVB 18 TPM button [/FONT]
    [FONT=verdana, helvetica, sans-serif]4. System error- fault memory ABS/ESP [/FONT]
    [FONT=verdana, helvetica, sans-serif]A system error is indicated by the TPM remaining steadily lit and by an entry in the fault memory of the ABS/ESP control unit. (fault 2214 Tyre pressure warning).[/FONT]
    [FONT=verdana, helvetica, sans-serif]The control unit must be reset to its delivery condition [/FONT]
    [FONT=verdana, helvetica, sans-serif]Switch to vehicle self-diagnosis [/FONT]
    [FONT=verdana, helvetica, sans-serif]-Select function 03 - Brake electronics[/FONT]
    [FONT=verdana, helvetica, sans-serif]-Select function 04 - Basic setting[/FONT]
    [FONT=verdana, helvetica, sans-serif]-Select channel 042 - press the Activate button[/FONT]
    [FONT=verdana, helvetica, sans-serif]Then initial calibration must be performed - see item 1 [/FONT]
    [FONT=verdana, helvetica, sans-serif]5. Adapt tyre size[/FONT]
    [FONT=verdana, helvetica, sans-serif]-Select function 10 - Adaption[/FONT]
    [FONT=verdana, helvetica, sans-serif]-Select channel 01[/FONT]
    [FONT=verdana, helvetica, sans-serif]Enter the number 0 and tyre size 15 inches[/FONT]
    [FONT=verdana, helvetica, sans-serif]Enter the number 1 and tyre size 16 inches or larger
    let me know if it sorts it out
    [/FONT]
  2. NHN
    29,328
    1,708
    Sorted inbox, replied with solution found.
    Butttttt, all that info above is very very much appreciated mate.
    Thanks again.
  3. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    lol, you busy PMing again Nige !!!
  4. NHN
    29,328
    1,708
    Not so much girl, keep missing you on msn though huh, oh sugar msn isnt even open, oops lol
  5. Sarah's A3
    5,920
    30
    lol, we have had such bad internet connections but all sorted now so will log on
  6. N8
    17,163
    718
    Nigel's box is always full :wub:
