Newly painted calipers... With pics.
stacey bear Apr 24, 2011
  1. stacey bear
    stacey bear ST8C3Y
    200
    Happy Easter to all at Audi-Sport, hope your enjoying the weather.
    Well the time has come and I've just spent most of my easter sunday painting my calipers and cleaning my wheels, followed by a BBQ and some cold beers.:yes:.
    Here are the pics.....
    Cleaned inside and out...
    Oh I would like to add, if I had silver or black paint I would have done the carriers and the holding pins either of those but reds good for now...
    Front Wheels and calipers all done.
    Again I'd like to have done the carriers black....
    Rears all painted and clean.
    All polished and painted. Job well done if I dont say so myself...
  2. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Good job mate.
  3. GeneralWest
    GeneralWest Member
    168
    Good effort. I want to do my callipers soon.
  4. wayne1.8t
    wayne1.8t Member
    150
    Good job that pal they look well behind your wheel. Think I might do mine next week when I have a go at polishing my wheels! What paint did u use?
  5. stacey bear
    stacey bear ST8C3Y
    200
    Thanks Wayne1.8t, i just use hammerite smooth paint. Got two lots of the 250ml tins and have only used 1/4 of 1 tin. I did 1 caliper at a time. Just did a quick once over with a small wire brush, one coat of paint, then washed the wheel in and out with some swafega alloy cleaner then back of to give the caliper another coat then stuck the wheel back on. I worked round all four wheels in the same way. It took about 4-5 hours in total with little breaks inbetween tho.
  6. A3 liam
    A3 liam Odt
    59
    Nice job, doing mine tomorrow did you spray or brush?
  7. stacey bear
    stacey bear ST8C3Y
    200
    I used a brush, the brush marks dont show, i didnt take off the calipers and housings so its not the best of finishes..
  8. stacey bear
    stacey bear ST8C3Y
    200
    Sorry S3 RAV didnt mean to give you a dislike.
  9. A3 liam
    A3 liam Odt
    59
    I'm going to try spraying, chosen gloss black for mine after the subtle look, brush marks aren't visible might try brushing if I get frustrated
  10. wayne1.8t
    wayne1.8t Member
    150
    Defo will be having a go now seen yours, will take my calipers of thoe I no what I'm like with a brush it will be everywhere.ha
    Are you gona do the rears aswell?
    If u haven't already that is
    Edit: just noticed your last pics they must not of loaded up b4.... They look great not sure what colour to go for myself.. Yellow or red I was thinking.. Hmmmm
  11. stacey bear
    stacey bear ST8C3Y
    200
    I think it depends what colour your car is. I put a post up a few weeks ago and asked for opinions. Red came up alot. I'm glad I went with red, it does suit the car. Yes a brush can be messy, I found a small ish one about 1/4 to 1/2 in wide. Was a cheap one tho but done the job.
  12. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Mine are getting done in satin black soon as they're a bit manky!
  13. Gavin G
    Gavin G Active Member Audi A4 S-line owners group TDi saloon
    181
    30
    Nice work i did mine last week, used hammerite aswell. Using a brush is the only way to do it imo, the spraying doesn't seem to stick well ;)
  14. wayne1.8t
    wayne1.8t Member
    150
    Did my front ones today I took the calipers off to do them. I've put them back on but have no brakes.
    I'm going to bleed them as I lost a little fluid.
    Do I just bleed the 2 calipers or the master cylinder or do I do both???
  15. stacey bear
    stacey bear ST8C3Y
    200
    You should be ok to just bleed the calipers youve took off. I'd make sure you don get to much fluid on your freshly painted caliper tho as brake fluid is a great paint stripper. A good wat to bleed your brakes is to get hold of an empty plastic milk bottle and lid (one of the small ones, think there 500ml) and put a piece of pipe (fuel hose) through the lid. Fuel hose is the right size to fit over the bleed nipple quite snug. This way all your fluid will go into the bottle and you'll be able to see any air as youll get bubbles in your bottle.
  16. wayne1.8t
    wayne1.8t Member
    150
    Great thanks alot I'll do it in the morning, gona do my backs aswell didn't have time today. Hopefully won't be as dirty as the front they were a pain to clean up.
    I'll get some pics on 2moz
  17. wayne1.8t
    wayne1.8t Member
    150
    Got them finished today. Spent most of the day bleeding my brakes which wasn't fun had trouble with the nuts on the bleeding nipple. All good now
    Just gona keep them clean now I don't fancy doin it again in a hurry.
  18. stacey bear
    stacey bear ST8C3Y
    200
    Well done wayne1.8t. They look really good behind your rims. You've done a good job mate.
  19. wayne1.8t
    wayne1.8t Member
    150
    Cheers pal! does look better now just look small now there more noticable imo.
