Newbie to Audi...help please
imported_WRX2A4 Sep 15, 2004
  1. imported_WRX2A4
    imported_WRX2A4 Guest
    I am a competent mechanic and I do not know enough about tuning these Audis. I just bought a 2001 A4 Quattro and I have some questions.
    What is the stock boost?
    What is a good boost to stay at when tuned?
    What are good ECU options?
    What are some normal mods for these cars?
    What is the difference between the S4 and the 1.8t (motor size, type, transmission, specs)
    What are good injectors for this car? What do they run?
    Does a turbo swap (T28) require a larger fuel pump or is the stock large enough?
    That is all for now...I'm sure I will come up with more
    Thanks!
    Dan
  2. congrats on your new buy...i also just bought the same thing.
    im pretty sure the stock boost is around 8-9. a good ECU option that everyone has been telling me to get is APR's v 2.0. you will need to replace your DV and your boost will go up to around 12-14....
    thats all i know...still learning
    AL
  3. imported_WRX2A4
    Thanks for the help!
    D
  4. dann959
    dann959 Member
    91
    most turbo on audis will go with a k03s or the k04 both these kits come with all the parts required and new fuel system accesories not sure about the fuel pump though my feeling is it wont have to be upgraded
  5. imported_WRX2A4
    Thanks again!
    D
  6. K212
    K212 Member
    115
    Normal mods include:
    chip, intake, turbo upgrade, diverter valve, exhaust, turbo downpipe, front mount intercooler, new silicone tubing...
