Newbie - Requiring help - Rear clunking
lgooch Aug 21, 2010
  1. lgooch
    lgooch Well-Known Member VCDS Map User
    1,195
    168
    Just picked up my new car today - A3 1.9tdi Sport with lots of factory extras.
    However on the way home noticed a a clunking noise coming from the rear when going over bumps.
    Any idea what this can be. I at first thought it may have been the spare wheel in the boot not fastened down, or the boot floor bouncing around, but all seems okay
    Any ideas
  2. SneakaFreaka83
    SneakaFreaka83 ASN is hazardous 2 your wallet
    348
    does it sound like a clunk or a rattle dude as the heat shields around the exhaust are kinda prone to getting loose and may need clipping back up?..
  3. lgooch
    1,195
    168
    Defo a clunk, just hope I have not bought a wrong un. Didnt do it on the test drive, but having said that didnt take it down any rutted roads.
  4. Harrelson
    Harrelson Member
    173
    Take it back and explain.
    Had the same noise when mine was new but only when parking. Turned out to be the brakes....
  5. lgooch
    1,195
    168
    I think it might be the boot floor as when i tap it, it sound like a sheet of plywood rattling about. I am gonna take everything out of the boot, i.e. floor, wheel, jack, parcel shelf etc and take it for a spin later to see if it still does it.
    If it does I have a 12 month warranty with the car so I will take it back to the garage
    I will let you know
    Cheers chaps
  6. Scott
    Scott Well-Known Member
    1,306
    126
    Don't think it will be much.
    There's a plastic shield which "covers" or protects the rear shocks I think and I've been told they can break and rattle.
    Wobble the exhaust by hand, when it's cold obviously, and see if you can hear it then.
  7. lgooch
    1,195
    168
    Scott
    Your absolutely spot on
    I took everything out of the boot, spare wheel etc and went for a spin. Still did it.
    i didnt understand what you meant by the plastic cover on the shocks. I thought you mean the circular dirt cover up in the top of thw wheel arch. Rattled them but did not move really. Then got under the car and noticed the flat black plastic cover under the shock/control arm. Offside was okay but near side had about an 1" of play in it. some of the plastic pegs had snaped off so just drilled some 5 mm holes and stuck some M4 bolts through it and voila, movement is gone and so in the noise.
    Well happy and cheers Scott !
