Newbie, Black smoke :(
gmars70970
Hi all,
I've just bought a 2005 TDI avant s-line (140bph) starting to have problems already :( Hopefully somebody will be able to help.
The car drives fine when under load. The problem seems to be when driving sensibly then accelerating, theres loads of black smoke out the back and lack of power, if I change down a gear and accelerate then theres no problem. Also today when I started the car it was smoking heavily, I had to gently convince it to rev up. It then ran fine again. Hope this makes sense ;)
I removed the EGR valve and cleaned all the gunk out it but doesn't seem to make any difference.
Any suggestions would be appreciated. Thanks in advance
Graeme
Hi deian3387
I've got a hand held scanner that says no codes found. Also theres no warning lights on the dash board. I've checked all the pipes but i'll go over them again today.
Do you know if the 3mm pipe going into the EGR valve should have pressure to it? I can blow / suck into this pipe with no resistance
IMG 1258IMG 1257IMG 1259
Looks like a new EGR Cooler fitted. The small rubber pipe on pic three is the one i'm wondering if there should be a vacuum.
Black smoke is an indication of incorrect fuel combustion/mixture i.e. not enough fresh air. Could be anything from a boost leak or blocked air filter to an EGR valve stuck open.
With regards to the vacuum pipe on the EGR valve, I'm pretty sure the vacuum is only actuated to the valve when EGR is required by the ECU. Therefore no vacuum = NO EGR (valve closed). But don't take my word for it as this is only my experience with different engines.
Hope that helps, Az.
thanks A4_Majik,
I fitted a new air filter this morning hoping that was possibly the problem. No change tho.
I'll spend the afternoon checking pipes etc. As i said under acceleration its fine, to me its similar to flooding with fuel, but I'm no mechanic
I had the same problem when I filled up at Sainsburys, now I use Shell I have never had the problem since.
im with sidi on this one, when i first got my a4 i had quite a bit of black smoke using cheap fuel, swapped onto the Vpower stuff and all is clear the only time u can tell my car is a diesel is when i boot it and the engine revs right round :p
Thanks guys,
I put £30 of diesel in yesterday and it does look slightly better,not sure if its the fuel or all the buggering about i've been doing.
I'll go & fill up with vpower today
413
899
819
866
905
